PreComposed layers are blurry at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 24th, 2013, 01:24 PM   #1
Hi All,
I'm rendering a video in After Effects CS6 and I'm finding my pre-composed layers are blurry. I'm using HDTV 29.97 1080p for the composition settings and the pre-composed layers are the comp size. When I create animations using high res images and text they look great within the pre-composed layer, however when I drag the pre-composed layer into the comp layer the images and text become blurry. Does anyone know why?
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old May 24th, 2013, 01:43 PM   #2
Re: PreComposed layers are blurry
Found the answer thanks
Old May 29th, 2013, 06:55 PM   #3
So how about sharing the answer??
Battle Vaughan is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
