PlayStation 3 Firmware (2.20) Soon!
I noticed that amongst the list of "other" features that this new update will add is apparently the ability to play WMV and DivX videos which are more than 2GB in size (the current limit on the PS3 for these formats) and enhanced web browsing allowing downloading of video content and streaming. Apparently this firmware will be out before the end of March. :-)
This means I will be able to burn longer playing HD videos that I've shot/edited onto DVD+R's for watching on my HDTV (typically, at present, I get around 20-22 mins maximum of HD video on a DVD+R with .m2t files.) Full list of enhanced features in link. http://www.engadget.com/2008/03/20/p...ray-this-mont/ |
Andy what is your workflow for doing this?
.m2t HD files on DVD+R to play on PS3
Steve, here's one thread on this that I started some time ago. There have been others in the last few months that a search on PS3 should bring up. Basically, when I've finished my editing (in Vegas 7e, and I typically only edit in HD now) I just save a file in the normal HDV template and burn that on a disk or drag it to a flash drive. Then to play on the PS3, make sure you are in the Video folder (film frame icon) and use options (triangle button) to "show all files" (on the DVD+R or the USB Flash drive), select the one you want and sit back with a beer or two enjoying the full spectacle of your work in HD!
http://www.dvinfo.net/conf/showthrea...&highlight=PS3 Since the above linked thread was done Sony enable DivX playback on the PS3 (around Xmas 2007 time, can't remember which Firmware version it was but it was probably 2.0.) After that, I was typically putting DivX HD videos (often from the recently departed stage6.com site) either onto DVD+R's or more typically just on 4GB Sandisk U3 USB flash drives. |
I used UPnP to get a 4.8GB m2t on my PS3 and it plays fine. Whether the file is split on the drive I'm not sure, but it plays.
Since this is a major update, I best do it when it comes out. |
I don’t have any WMV and DivX files that are over 2 gigs so that fix doesn’t affect me but there are still DivX files that are incompatible and I’m hoping this update fixes that as well. How can the PS3 be DivX certified when it’s not compatible with all DivX files?
The PS3 can already steam videos for Google Video and YouTube but it appears that 2.20 would have made streaming files from Stage6 possible. They should have fixed that before the disappearance of Stage6 not after! At least in the bright side, this update proves that all PS3s are upgradeable to Profile 2.0. |
Just curious: Is DTS-HD supported on the PS3?
Won't the PS3 recognize AVCHD in an M2T file?
All of this is second-hand. I make no claims to any special expertise on the PS3. I'm just a very satisfied owner, who'll be even more satisfied when the DTS-HD MA codec is supported. |
Yeah, it's a bit of a issue, PCM 7.1 or DTS-HD... Some go one way while others go the other. Hopefully PCM 7.1 would become standard soon.
Here’s a good article on what’s in store for the PS3’s media capabilities.
Original Japanese: http://www.watch.impress.co.jp/av/do...0403/rt057.htm English Translated: http://babelfish.altavista.com/babel...03%2Frt057.htm This site really needs to hire an English translator. |
