Multi-Disc DVD Cases at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
Distribution Center
PC or Mac, how to take your video to DVD or the Internet.
Old November 14th, 2014, 09:21 AM   #1
You might file this under OCD, but I am wondering what others do:
I film a local HS sports club. Parents purchase the entire season which will consist of 16-20 discs depending on how far the team makes it in the play-offs
The Multi-Disc DVD case that I will be using holds a maximum of 24 discs. That is, there are 12 double-sided sleeves that can be inserted/removed as desired.
Question: When I deliver the final product, do I remove the unused sleeves so the Case only holds the Discs that I produce? Or do I leave all 12 sleeves in there so the customer may put other discs in the case?
#1 looks more professional, #2 gives the customer flexibility.
Vince Pachiano is offline   Reply With Quote
Old November 29th, 2014, 11:32 AM   #2
Re: Multi-Disc DVD Cases
I always remove the unused sleeves.
Garrett Low
www.GLowMediaProductions.com
Garrett Low is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center
