Interlacing problem
Hi all,
I'm having problems getting some footage decently on DVD. Here's the workflow I already gave a try (PAL video): 1. I captured the footage of a Canon XM-2 in different clips using Vegas' capture tool. (I used Vegas because Avid gave me problems + Vegas captures all clips seperately for easy editing) 2. I imported all of the different clips into Avid Xpress pro and started editing. 3. I needed to add the titles and credits I had already prepared in Vegas, but Avid again gave me a problem in properly importing the titles. So I rendered out the full video/audio tracks into an uncompressed .mov file on the following settings: No compression 720*576 Field order: upper/odd field first (PAL?) & lower/even field first (tried both already once) 4. I imported this finished clip into Vegas and added titles and credits. 5. I cropped the 4:3 footage into 16:9 with letterbox and made the following project settings: 720*576 Pixel aspect ratio: PAL widescreen 25 fps Gaussian motion blur deinterlace mode: none/blend fields (tried both) 6. I then render this project as a 16:9 display MPEG-2 PAL video stream 7. I add the MPEG-2 to DVD architect on following settings: Video: PAL widescreen 8. I insert the disc into a DVD-player and... Menus: OK Widescreen: OK Audio: OK Interlacing: NOT OK I'm getting interlace-artifacts on all somewhat more rapidly moving subjects. If I turn on the 'reduce interlace flicker' on the video properties page in DVD architect, the interlacing indeed reduces but a jittery movement of the subject takes it's place. I've already managed to render out a DVD before without any problems, but this one is giving me headaches. It is however the first widescreen project I render out, but I suppose it being in order has nothing to do with the interlacing.... The things I think might cause the problem: - Field order: for PAL video should I now take odd or even field first? - The 'deinterlace method' in vegas: blend field, interpolate or none? - The settings in the final rendering: odd/even field? perhaps try the regular template 'PAL DVD' and just change the display to 16:9? ... Perhaps the fact I 'render' twice (first avid uncompressed, then vegas on MPEG-2) causes the problem? I'm kind of losing myself in all these settings, and since rendering takes so long and I'd like to finish this by friday.... I really am losing courage here... Sorry if this is somewhat a repost of something, but I just need some help. Greetz, Merlin |
Hey, I think I know what's the problem. Had similar stuff happening so it might be it.
Go into the menus of the DVD player and change it to view the material on 16:9 TV. I had a 16:9 DVD which played fine on mine, but when it got to a client of mine it looked just as you described, but then I changed the settings and it was fine. Hope it helps. |
Thanks for the reply, but it doesn't seem to solve the problem.
