What format to convert to for DVD at DVinfo.net
Old December 30th, 2004, 05:41 PM   #1
I am using a Canon GL2 with FCE for post. After I am done with my project, and want to export for DVD, What is the best format to convert to? I converted one to MPEG-4 and after using iDVD to burn it, I stuck the DVD in my home DVD player, (excuse the lingo) and it looked like crap.
Please, someone tell me this is not as good as it gets.
Jeff Parker
Motion Synonymous To Thought
stickandmove.org
Jeff Parker is offline   Reply With Quote
Old December 30th, 2004, 09:57 PM   #2
iDVD will convert your files to MPEG2 which is what is on a DVD. In iDVD set your preferences to give priority ty Quality rather than Speed.
In FCE, export your footage as Final Cut Movie, choose Include: Audio and Video make sure the Make Movie Self Contained box is checked.
This will give you a full resolution file to use in iDVD. Whne you export as an MPEG 4 you are compressing the file to begin with, then iDVD compresses it again.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old January 2nd, 2005, 06:37 PM   #3
Following Dave's advice, make the self contained movie. If you have Toast 6, NTI DragonBurn... just drag it in... You can make a DVD or vCD. You don't get any fancy graphic interface, but it works very well.
Valeriu Campan is offline   Reply With Quote
Old January 2nd, 2005, 07:15 PM   #4
Thanks Dave and Valeriu, with your help I did it right this time. Just kind of thought it would look better than it does. Im using a GL2 and it seems my Sony D8mm looks every bit as good. I am sure the Canon has other settings I can play with. Guess I want too much too fast. Is it just me or does the DVD's you rent look better? Just seems like I could get a bit closer to a crisp looking video. I am looking at it on a Mitsubishi 1080i, and even in 480 it's less then I thought.
I hope it is just me doing something wrong. Thanks guys.
Jeff Parker
stickandmove.org
Old January 2nd, 2005, 07:36 PM   #5
Jeff,
I didn't know you were viewing it on a Hi Def set. In general, standard def stuf fis going to look worse on the and HD set than it will on a standard def set.
Rental DVDs of major hollywood movies involve much more than just shooting footage and putting it on a DVD. Obviously the budgets are larger and the situations are mostly controled.
Old January 2nd, 2005, 07:46 PM   #6
Dave, I kinda thought that was the reason. I was just hoping with my GL2, MAC G5 and I could turn out a better looking video. Tell me this Dave, If I were to do all my editing then put it back on tape (mini dv) then play it on my TV, would it look better? The wheels in my head are turning as you may tell. Looked at your site and thought... This guy knows his stuff! Hope I am not asking too many questions.
Thanks Dave
Jeff Parker
stickandmove.org
Old January 2nd, 2005, 09:31 PM   #7
Jeff,
It would probably look better but not by much. Also, you would not be able to distribute your work as readily.
A thought just came to mind. If you are viewing your stuff on a HD set that is also widescreen 16:9 and shooting in 16:9 mode on a GL2, then you are losing resolution which will cause a degradation in quality. The GL2 does not shoot true 16:9. It chops off the top and bottom of the frame to get the 16:9 aspect ratio. iDVD currently does not support 16:9 either. There is talk about the next version supporting it though.
Old January 4th, 2005, 09:51 PM   #8
I can verify what Dave just stated. Shot some game action in 16:9 and the video is not nearly as crisp as std 4:3 format, from a Canon as it is a 16:9. I created a iDVD CD, with 4:3 and picture quality on a Sony HD TV is excellent. I also turn off Digital Zoom to maintain quality.
Joe Matiacio is offline   Reply With Quote
Old September 3rd, 2010, 01:45 AM   #9
MPEG 2.
Convert HD format to iDVD
How to convert HD footages for authoring with iDVD?
Hale Nanthan is offline   Reply
