First day with green screen at DVinfo.net
Old July 16th, 2009, 09:34 PM   #1
Green Screen Test on Vimeo
worked amazingly, $35 on ebay for 10 feet by 20
naked ex1
Jon Sands is offline   Reply With Quote
Old July 17th, 2009, 02:20 PM   #2
Cool. That's was very entertaining.What software did you use to key?
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old July 17th, 2009, 03:33 PM   #3
Keylight used in AE
Old July 17th, 2009, 06:41 PM   #4
Hi John,
Can you direct me to the site you purchased this green screen from.
Old July 17th, 2009, 07:09 PM   #5
You can get the material from Michales, Walmart, etc as well. I think I paid $30 for my 9 x 12 muslin green screen. And Keylight works really well with minimal work. You can do a bit better with some techniques found in AE CS4 Visual Effects and Compositing book.
It's fun for sure. The shot you have there with the guy with machine gun.. did you color correct it? It looks like he and the background are lit the same.. so good job if you did and how did you do it.. if not, well, good job getting lucky. :D
Kevin Duffey is offline   Reply With Quote
Old July 17th, 2009, 10:47 PM   #6
yeah he was graded, curves mostly, some desaturation, and some lighting in ae to give the same tiny little vignette / cast on him and the background
and I'm not sure if were allowed to link to ebay or not but here it goes.........
10 X 20 Ft Chromakey Green Screen Muslin Photo / Video - eBay (item 370226945397 end time Jul-18-09 18:00:58 PDT)
Old July 18th, 2009, 03:10 PM   #7
Thanks Jon,
The product looks great but the shipping into Australia is going to far at $127 plus the product on top.
I'll try and find one here in Australia.
Cheers
Old July 22nd, 2009, 02:19 AM   #8
If you have a blank wall then you can simply paint it green. Most good hardware stores should be able to mix up a pot of bright green. You can of course use any colour as a Key, but Green and Blue are the industry standard.
The key to good Keying is with the software that your using. Keylight in After Effects is excellent. I also use the Matrox RTX2 which has hardware keying, it is very quick (instant) and very accurate.
Vincent Oliver is offline   Reply
