EX1 SxS Files Straight to the SATA Drives?
Macbook Pro 17"
Firmtek 5 Bay SATA EX1 SXS Cards What is the best way to get the files off of the cards and to the Firmtek SATA drive WITHOUT having to first copy the cards to the internal drive first? in other words.... I would like to NOT have to copy the SXS cards to the Macbook Pro's internal hard drive to get the files to the Firmtek SATA drives. Could I use some kind of SATA/ Firwire adaptor like this? http://www.wiebetech.com/pressreleas...ease.php?id=81 What I really would like is a Macbook pro with 2 Express 34 slots :) Any thoughts? |
Bump bump.....
Anyone? ASAP please :) |
I'm using pc but when i offload the cards using clipbrowser, i can choose the destination folder/drive.
So sxs card goes into sxs slot on laptop, external hard-drive gets plugged in via usb and then i transfer from sxs card to external drive. So as long as you can plug the Firmtek 5 Bay SATA into the mac then I presume you can do the same . Paul. |
Hi Paul,
Thanks for your help :) The thing is that the Firmtek connects to the Mackbook Pro via the Express 34 slot so I can't have an SxS card in the same slot at the same time. Anybody else want to take a shot at this? I know there must be some kind of SATA to Firewire connector cable. Sure the transfer speed might not be as fast but thats not an issue. |
Here we go!
http://www.geeks.com/details.asp?inv...UTS225&cat=CCD Now..... can I just pull the files off of the SxS cards to the SATA drives connected via the USB 2.0 port? Sure hope so. |
well, what firmtek drive is it? does it require a controller that support port multipliers, is it RAIDed? OSX software raid (diskutil)? the sata controller in that usb-sata converter device seems to support PM and software RAID, but it might be a problem switching between two different SATA controllers on the same software RAID, but it might be fine, i guess its hard for me to say for sure. USB will certainly be up to 10x slower than SATA in this case (250MBps max vs ~25MBps max)... but you say you dont care, so i guess thats fine. could always just buy a separate usb hard drive, but i suppose you have a reason you want to go straight to this firmtek drive and not another drive.
Good questions Noah.
I wish I had the answers..... http://www.firmtek.com/seritek/seritek-5pm/ It won't be raided. latest Mac OS "could always just buy a separate usb hard drive, but i suppose you have a reason you want to go straight to this firmtek drive and not another drive." yep, carrying enough heavy gear and hopefully this is the last little piece of the puzzle. Pretty tough to be a one man band and be fully dialed on every little piece.... A big beer if'n you can sort this :) |
Simple.
You need the ExpressCard for the SxS, so you want the fastest connection for your external drive. That is FW800. It can be almost as fast as SATA in practical terms (for single disks). I presume you also want to use a bus powered disk for mobility. Unless you can plug into AC power. Get a 2.5" sata disk and put it in a housing like this or get a complete drive. Get a 7200rpm drive if you also want to edit or just if you want speed more than space. Larger 2.5" drives are 5400rpm and a bit slower (but fast enough for quick SxS offloading). George/ |
hmmm.... so a 5 bay drive enclosure but without the speed of esata or redundancy of RAID... whats the point of lugging something so large around then? is it that you dont care abotu copy speed but then when you arent offloading sxs you use the firmtek for on-set editing?
id check the chipset on the usb adapter but it should work as its probably the silicon image sata controller that supports PM and is compatible with the firmtek which also uses a silicon image controller. theres always the option of using the EX1 as a usb sxs card reader and then using your expresscard sata for the firmtek... but that would tie up the camera. whats the deal with firmtek anyway? isnt it like $500+ for the enclosure? ive used a similar 5bay enclosure with the same chipset that i got for about $200... whats so special about the firmtek? |
Well done Noah.
"hmmm.... so a 5 bay drive enclosure but without the speed of esata or redundancy of RAID... whats the point of lugging something so large around then? is it that you dont care abotu copy speed but then when you arent offloading sxs you use the firmtek for on-set editing?" Bingo! I will be shooting/ editing a doc around the world for the next few years and will have a flat to set up in. "theres always the option of using the EX1 as a usb sxs card reader and then using your expresscard sata for the firmtek... but that would tie up the camera." But doesn't the USB 2.0 only transfer the footage as 25mbs even when it's 35mbs??? "whats the deal with firmtek anyway? isnt it like $500+ for the enclosure? ive used a similar 5bay enclosure with the same chipset that i got for about $200... whats so special about the firmtek?" I went with Firmtek because of the great reports and the size. Apparently it was started by a bunch of ex-apple guys. "id check the chipset on the usb adapter but it should work as its probably the silicon image sata controller that supports PM and is compatible with the firmtek which also uses a silicon image controller." I don't know how to id the chipset of a usb adaptor. Any thoughts? One big beer coming right up...... you'll have to come to Amsterdam to get it ;) |
You could always get the sony sxs card reader, plug that in via usb and transfer from the card reader through the laptop into the firmtek.
An 8gb card will take aroung 7 mins to transfer using the sony card reader. Paul. |
Nice one Paul :)
Any idea how much for the "SONY" card reader or where I can find one? I'm currently in Amstedam. |
Sony card reader is $250 at B&H. Plus it needs AC power
USB 2.0 to SATA adaptor is like...... $8. Hmmmmmmm........ |
That's because the SxS cards implement the ExpressCard PCI Express interface so they need to be connected to a PCIe host (like the Sony reader or a notebook) and then it can be bridged to USB. A little more complex than the SATA-to-USB bridge (and manufactured in different quantities as well).
If you need a stationary setup, a RAID-ed eSATA (via ExpressCard) in combination with reading the SxS cards via USB is the easiest solution. You can use the camera USB connection to read the data from the cards just like with the external reader, albeit a little slower. You can also capture SP-mode (HDV) video from the camera's firewire, but why would you want to. George/ |
Big thanks George :)
Please tell me: Does the USB 2.0 only transfer footage as 25mbs even when it's shot at 35mbs??? |
Via firewire (i.Link) you can play out a video and capture it on a FW capable system. This only works for 25Mbps SP mode (HDV compatible). George/ |
Right-o George.
So I understand it will copy the files as they were shot 25mbs or 35mbs with all the associated metadata. Copying back to the camera the video..... will have different qualities. Like what? So I should be able to pull the files off of the camera via USB 2.0 and place them into the external SATA via Express 34 slot. Great :) |
You can play out (record) via i.LINK to the camera, but only for HDV compatible signals. See page 115 of the manual. George/ |
Thank George :)
Checking the manual..... |
Jonathan,
The Sony USB card reader will transfer any format the camera will shoot, it just loads slower than using the PCIExpress 34 slot. When you were first setting up your system, this was the main reason I was suggesting FW800 drives. It makes it much faster and easier to load the files from the cards. What you give up is the speed of the SATA RAID. It is a judgement call. Good luck with your trip, Daniel Weber |
Hi Daniel,
Thanks for jumping in here. I'm not in a news room so speed is kind of meaningless at this point but I do hear you on the FW800. Also I have 4 16 gig and 2 8gig cards so I don't expect to be in a bind. I'd just be happy to come home a dump the cards while making dinner.... it's not like it takes a month to transfer err somethin' Just putting the final pieces together before stepping out..... along with way to many Heinekens. Ahhhhh the Dutch ;) |
