retrieving files during record FS-2
If the Fs-2 being used for continious recording 24 hrs a day, are the recorded files available true the network connection.
Anyone ever used this kind of workflow or tested it. |
Hi Rens,
Sorry for the late reply. You could use FS-2 for long recordings (such as a 24-hour recording). It comes with a 120GB internal drive (which is just under 10 hours of recording), but you can also daisy chain up to four standard FieWire drives from the unit. When one drive fills, it will begin recording to the next drive. It is possible to access the clips on the connected disk drives from a network via the Ethernet port using FTP. Hope that helps. Matt McEwen |
