Record to disk software, Which to take? feedback needed.
hi all ,
i'm currently trying to get my dvx100b to go tapeless, trying to save the camera head hours. After a few search on the net. i come down to these two software companies.They claim to allow me to directly record into my Powerbook, into my external harddrive. Both allow me to use my powerbook as a external on site monitor. I need to know if anyone has any experience with these software. I am not intrested in DV RACK . As i use a Mac User DV Monitor Pro http://www.redlightningsoftware.com/...tor%20Pro.html Scopebox. http://www.scopebox.com/ Scopebox has HD, but i only have a DVX100b. it allow me to upgrade to HD later (at a cost). one cost twice or more than the other. They both look good. And both has alot of features.This is not about personal prefrence,but I need feedback on certains issues. My main concerns are drop frame, crashes. User friendly capabilities.Which one is more reliable. Does any one have any experience with them? Also as i am currently using a WRD35PRO (35mm adapter)with my DVX100b. I actually like to know if any other software out there, that allows me to "record" the "flip image" from my adapter? Both the softwares has "Flip" function. But they don't allow you to record the flip image. You got to do it in post. Thank you in advance for any feedback, David |
iBook G4, QT Pro 7, 250 GB WD 7200 RPM IDE in external FW case, connect 4-pin from camera to external drive which is connected to FW port on laptop and it works great. I also have FCP 5.1 on my iBook and that records in "native" format. Just use non-controllable device settings. I learned that from someone on these boards. The QTPro method required a render to DV using Compressor. I don't edit on my iBook, I just use it as a portable setup. I'm filming my first "real" event this weekend with this setup and I'll post the results when I get done. Grant |
http://www.scopebox.com/forums/index...rum=1&topic=10 |
Grant |
