Lightest battery solution with d-tap at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions
DTE (Direct To Edit) systems which bypass the video capture process.
Old December 13th, 2016, 06:17 AM   #1
Hi all
I want to make a very light camera right that supports a shogun via d-tap. I'm basically looking for a very light weight battery pack with d-tap, I really don't want a standard chunky anton bauer/vmount battery.
Anyone got any suggestions of an alternative or a very light weight lower capacity battery of the types mentioned ?
Adam Jones is offline   Reply With Quote
Old December 13th, 2016, 02:34 PM   #2
Re: Lightest battery solution with d-tap
The SWIT S-8U93 is exactly what you're looking for. If you have an A7S/A7R/a6300, it has a USB charge port that can supply the camera with power at the same time as supplying D-tap. And if you use a battery plate for the Shogun, you can add another thing to the spare D-tap on the battery.
S-8U93 86Wh Battery For Sony BP-U Series
It charges in a Sony BC-U1 charger.
I wait for the day cost-efficient global shutter 60fps capable CMOS sensors emerge for use on major manufacturers' cameras. (Sony, Canon, etc.) Rolling Shutters are a plague.
Old December 14th, 2016, 08:09 PM   #3
Zacuto has a small battery that rides on 15 in. rods.
Jim Michael is offline   Reply
Texas Media Systems
(512) 440-1400
Austin, TX
New York, NY
Z.G.C.
(973) 335-4460
Mountain Lakes, NJ
Abel Cine Tech
(888) 700-4416
N.Y. NY & L.A. CA
Precision Camera
(800) 677-1023
Austin, TX
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions
Google
1998-2017 The Digital Video Information Network
