All Ebay Listings 2015 - Page 2 at DVinfo.net
Go Back   DV Info Net > Community Marketplace > F.A. on Ebay
F.A. on Ebay
For *individuals* to post their items listed For Auction on Ebay.
Old March 3rd, 2015, 06:34 PM   #16
Sony DVF-L700 7" Full HD LCD Monitor
Hi all,
I'm selling this monitor as I recently sold my F55 package.
The monitor is in excellent, like new condition. One owner, never sub rented. Absolutely spectacular image quality.
Ebay Listing:
Sony DVF L700 7" Full HD LCD Monitor Excellent Condition | eBay
Product highlights:
-Native 1920x1080 Resolution
-Compatible with Sony F55 and F5 Cameras via Sony monitor connector
-Compatible with all other cameras via SDI cable
-Supports 4k and 2k signals
Includes:
-Sony Viewfinder Cable
-Hoodman Shade
-Lemo power cable
Peter Richardson is offline
Old March 3rd, 2015, 06:36 PM   #17
Sony VCT-FSA5 Shoulder Mount for F5/F55
Hi all,
Also selling this shoulder mount as I've sold my F55 package:
Sony VCT FSA5 Shoulder Mount for F5 F55 | eBay
Excellent Condition. Minor cosmetic wear but works perfectly. One owner, never rented.
Product Highlights:
-Enables hand held shooting
-Low Center of Gravity
-Sliding Balance Adjustment
-Stainless Steel 15mm support rods
-1/4"-20 Camera Tie Down Screws
-Intergrated foam shoulder pad
-Arri Compatible Mounting Rosettes
-Mounts to VCT-14 GR Plate (not included)
Includes:
-VCT FS-A5 Shoulder Mount
-15mm stainless rods (not pictured)
Old March 3rd, 2015, 07:00 PM   #18
Panasonic AG-MSU10 P2 Storage Unit w/ 500GB HDD
Hi all,
Selling my lightly used MSU10. When I was using P2 gear this was a life-saver in the field. It's been well-maintained, never rented out, and is in excellent condition.
Panasonic AG MSU10 P2 Media Storage Unit with 500GB HDD Excellent Condition | eBay
It allows you to download P2 cards to the internal drive (which can then be connected on its own to your computer) or, my favorite feature, directly to a HDD which allows downloads in the field with no laptop. Very fast and reliable, with data verification features.
Includes:
-AG-MSU10
-Drive Sled with 500GB HDD
-AC Adapter plus cable
-Battery Charger plus cable
-1 battery
Product Highlights:
-P2 Memory Backup
-Connects Easily to NLE's
-Copy directly to external hard drive - no computer needed!
-One-button copying
-USB 2.0 and eSata Interfaces
-Removable 2.5" Drive tray with 500GB Drive
-4x Real-time transfer speed
-Host/Device Functions
-AC/DC or Battery
Old March 3rd, 2015, 07:04 PM   #19
Panasonic AJ-PCD20 P2 Drive, 5-Slot Capable
Hi all,
This drive is in good/very good condition. Shows some signs of wear but is fully functional. I was the only owner and never rented it out.
Panasonic AJ PCD20 P2 Drive 5 Slot Capability Firewire and USB Compatible | eBay
Includes:
-AJ-PCD20 P2 Drive
-AC Adapter and power cable
Description:
The Panasonic AJ-PCD20 is a P2 drive which acts as a conduit between P2 cards and a computer. Specifically for use with non-linear editing systems, this drive can ingest up to 5 P2 cards at one time over FireWire or USB 2.0. When connected to either a MAC or PC the P2 cards will appear as one drive, making it extremely easy to browse through video footage. This direct-to-edit (DTE) approach saves time and money while eliminating cumbersome tape-based acquisition that can often lead to dropouts and time code errors.
Old March 3rd, 2015, 07:31 PM   #20
OConnor O-Grips Single Jointed Set
Hi all,
These are in excellent condition, lightly used - just a few cosmetic nicks and scratches. I used them with a C300 but they fit a variety of rods and cameras. Super strong and easily adjustable. I have a second set so am selling these.
Oconnor O Grips Single Jointed Set | eBay
Peter
Old March 3rd, 2015, 07:49 PM   #21
Century Optics DV Mattebox and Schneider 4x4 Filters
Hi all,
I originally used this setup with a Panasonic HVX200 and HPX170, but it may be compatible with other cameras. It's a nice, lightweight matte box, with a flip out shoulder brace and one rotating filter tray.
Filters are clear and in good condition.
Century Optics Camcorder Matte Box with 15mm Rods and Schneider 4x4 Filters | eBay
Mattebox is in very good condition, with some scratches and warping on french flag.
Mattebox Features:
-Two 4x4 filter trays - one rotating
-Fold-Out shoulder support
-Adjustable french flag
Schneider Filters:
-1 Schneider Clear 4x4 Filter
-1 Schneider Polarizing 4x4 Filter
Old March 25th, 2015, 07:41 PM   #22
Besteady One brushless gimbal
Besteady One
$1,990 USD O.B.O.
http://www.ebay.com/itm/171733105134...84.m1555.l2649
I found myself needing a gimbal to support larger cameras, so I’m selling my used Besteady One that I’ve been using with my Panasonic GH3. I purchased it via Quickstarter on 2013 without the factory handles, so I customized my own using express35 parts
What I liked the most about it:
• It takes cameras up to 4.4lb (2kg).
• The balancing is tool-less since it uses thumbscrews
• It has up to 3 profiles that you can switch in between just by clicking on the control button.
• The footage is very smooth and I only had issues when I didn’t balance the camera properly.
• It is very lightweight compared to the rest in this range, around 9lbs.
• I was able to change the zoom of the lens without rebalancing to tilt axis. I used the Panasonic 14-140 lens which extends as it zooms. I balanced it for a 35mm focal range and I was able to work on the 14-50mm range without a problem.
• Battery life. I was able to shoot a 12 hour wedding with just 2 batteries making sure I didn’t have it on when it wasn’t needed, but with the 4 batteries I’m including you could work on long shoot or an entire wedding without a problem.
• If you need a more free access to the top part of the camera, you can take the top part of the cage off.
• No need to do any programming, just tweak settings in the desktop manager application.
The foam of the base where you seat the camera on is damaged, so I just added a piece of plastic to make sure it doesn’t twists on me.
I’m including the following:
1. Besteady One
2. Cinestar adapter (for drone use)
3. Express35 Rig (the besteady is attached to this via 4 thumbscrews)
4. 4 batteries. I purchased 2 extra batteries myself, the black ones
5. 2 chargers. I purchased 1 extra charger.
6. Silk mini-quick release adapter. I do have the quick release plate, I just forgot to take it out for the pictures.
7. Xit XTHC40 Medium Hard Case. Forgot to take a picture of the actual case but I’m adding a stock one.
I spent $220USD on the 2 extra batteries and charger.
You can download the manual from http://www.acr-sys.com/download/BeSt...v1_0_hires.pdf
Here are some specs:
Mainboard 8-bit custom SimpleBGC / AlexMos
Sensor units 1 Inertial Measurement Unit: 3-axial gyro & 3-axial accelerometer on camera shelf
Number of profiles stored on board 3 profiles
Camera cage Two simple aluminium cheeseplates
Balancing Completly tool-less balancing
Camera weight range From 0,5 kg to 2,0 kg (from 1.1 lb to 4.409 lb)
Camera cage sensor enclosure Two piece aluminium box
Weight Basic option without Antivib: 1,07 kg (2.359 lb)
Main power cable Bare wires, JST connector
Rear arm electronics housing cover with LEDs Transparent plexiglass
USB connector on mainboard Revision 1: solder in two points, revision 2: solder in two points plus two positioning towers
Manager App From 1.0 to 1.3.3, 2.0+ after firmware upgrade
Classic Stabilisation mode Available, old version of strict stabilisation
Xtended Stabilisation mode Available, new version giving wider operational range
Follow mode Available, selectable for Pan, Tilt and Roll
Special connectors (combs) One 6-pin comb for RCU or Thumbstick
Feel free to ask me any questions you may have.
The gimbal is in fully working conditions. Returns are accepted only if there’s something wrong with it and it’s not stated in this post.
Tags: Ronin movi defy helix letus came freefly eagle Steadicam tiffen merlin blackbird flycam glidecam
All Ebay Listings 2015-1besteady-33.jpg   All Ebay Listings 2015-1besteady-34.jpg
All Ebay Listings 2015-besteady-6.jpg   All Ebay Listings 2015-besteady-26.jpg
All Ebay Listings 2015-besteady-7.jpg   All Ebay Listings 2015-z71rn-9n08sl._sl1500_.jpg
Bernardo Gutierrez is offline
Old March 27th, 2015, 09:07 AM   #23
fs100 kit EVF, screen, Zacuto base ends today
Sony NEX FS100 Camcorder Large Kit Case 7 inch Screen and EVF Anton Gold Mount | eBay
Everything you need but a lens for all day shoots... external EVF and mount plus Anton battery for shoulder mounting..... matte box, 7 inch LCD for tripod .... and wireless audio kit and handles for both.
Sony FS100 camera body with 10x10 hours
Berkey Systems top plate
Berkey Systems handle
Anton Bauer gold mount battery plate and FS100 cable
Anton Bauer gold mount battery by Switronix
original fs100 grip
7 inch Lilliput HDMI field monitor (takes Sony batteries)
External EVF HDMI screen and eye piece (takes Sony batteries)
original LCD eye tube
ultra thin flex HDMI cable
EVF mount
FMU 128 SSD memory pack
wireless lavaliere packs (full kit with lav and reg mic+cables for fs100
Genus Fader ND 77mm
2 mic holders
Zacuto Grip relocater
Zacuto baseplate
Carbon Fiber 15mm rods
original sony handle
matte box french flag, side flags, and lens donut by Kamerar
Glass ND filters for matte box .09ND and 1.5ND
converter to use Nikon F lenses
remote control for fs100 and various wires and cables
15mm rail block
Giottos plate
brand new Pelican 1510 with foam (new un cut)
Ray Lee is offline
Old March 27th, 2015, 01:15 PM   #24
Switronix Shoulder Mount w/ quick release & handles
Opening bid $50 ($248 new)
Switronix "HDV Pro" DSLR Shoulder Rig Mount with Quick Release | eBay
Zach Love is offline
Old March 30th, 2015, 04:09 PM   #25
Re: Besteady One brushless gimbal
New price: $1,640
Old April 4th, 2015, 12:44 AM   #26
SOLD! Thanks for looking
Old April 22nd, 2015, 09:38 PM   #27
For Sale Sony PXW-X160
Hi Hope its ok to post here Sony XD CAM PXW X160 | eBay
I have decided that I am going to stick with my EX3 and X200, due to Battery setup and Bolt, it just not suited to the X160.
So if and Australian shoppers are interested, I will consider offers also.
Rob.
Rob.
www.rpbproductions.com
robert@rpbproductions.com
HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP.
Robert Bale is offline
Old April 23rd, 2015, 02:53 AM   #28
Re: For Sale Sony PXW-X160
Robert, as a matter of interest on a separate point, have you managed to update your X200 to firmware 1.20?
My two X200's won't find/see the update...
Rob Hargreaves is offline
Old April 23rd, 2015, 06:14 AM   #29
Hi, no I haven't had a go at the FireWire, I seem to wait till I really need to upgrade. In my current work flow its fine at the moment.
Rob.
Old April 23rd, 2015, 05:48 PM   #30
SmallHD DP4 EVF Super Bundle
Smallhd DP4 EVF Super Bundle | eBay
Phil Hover is offline
  You are here: DV Info Net > Community Marketplace > F.A. on Ebay
