New Film Look and color correction software - Page 4 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 5th, 2006, 03:24 PM   #46
Greg, We will look into QT.
Alex, thank you for pointing this out. I will look to see if there is a patch for the HuffYUV codec out there.
As Chris mentions we have a couple cases where people are having problems rendering lengthy files. Because we have only received 2 reports of this problem, it makes it difficult to pin point the issue. We are working on it! And also looking into a new avi rendering engine. We may test this engine with the people that are having this problem to see if it fixes it.
The new 24p option has seen some changes and we are adding more functionality before the release. We have added a deinterlacing/24p adjustment screen so that the user can tweak and test the options in real time without having to render the video.
We will keep you posted of all progress.
NEW CinemantiQ: Film Look / Color Correction
Fast, easy, powerful and affordable.
http://mentemagica.com
MenteMagica CG Software
Alain Bellon is offline   Reply With Quote
Old May 10th, 2006, 04:02 PM   #47
Originally Posted by Alex Thames
Well...from the website you linked to:
"- One of our visitors reported bugs in HuffYUV 2.2.0: The new version 2.2.0 is one big bug. It just does not work at all. Opening the resulting AVI file always crashes Windows Explorer... It may work on some peopls PC's but not on mine (Win XP) and a lot of other people dont use the newer version either because it doesn't work."
Ah good catch there, my oversight. I did have some luck with very small files, but larger files just won't play for me.
Armin DeFiesta is offline   Reply With Quote
Old May 19th, 2006, 09:59 PM   #48
10-Bit Support?
Hello Alain,
I'm very interested in your product. Do you plan to support 10-Bit files in the near future?
-Geoff Murillo
Geoff Murillo is offline   Reply With Quote
Old May 22nd, 2006, 08:51 AM   #49
How would compare your product to Synthetic Aperture? Besides cost?
Boycott Guinness, bring back the pint!!!
Joe Carney is offline   Reply With Quote
Old May 22nd, 2006, 10:23 AM   #50
Hello All,
The update has taken a bit longer than expected due to the incorporation of a new AVI writing engine. It was a decision we had to make and we decided that it would make sense to introduce it along with the new 24p feature. We are doing the final integration steps.
Geoff, we don't have a date set for support for 10bit files yet.
Joe, I do not know much about synthetic apperture. I assume you are talking about their Color Finnesse product. It looks like a dedicated and advanced color correction application. CinemantiQ's aim is different. CinemantiQ is focused on ease of use and the emulation of certain visual aspects of what has come to be known as "the film look", including color correction, diffusion filters, and soon a 24p converter.
If you are after an advanced color correction system, and know how to operate such a beast, go with Color Finnesse by all means. I would have to say though that not many people need it or know how to take advantage of it. Colorists earn good money for a reason :)
Old May 22nd, 2006, 05:18 PM   #51
Canopus?
Will your product work with the Canopus HQ codec?
How does your pro0duct compare with DVFilm?
Nick Rinaldi is offline   Reply With Quote
Old June 3rd, 2006, 10:40 AM   #52
just want to know CinemantiQ does this features:
- 16 bit processing?
- auto scene detection/spliting?
- openGL accell or CPU+GPU render?
seems to be a great app!
Hornady Setiawan is offline   Reply With Quote
Old June 4th, 2006, 11:12 AM   #53
Nick,
The codec should not be a problem as long as it is a readable DirectShow codec. I'll try to give you more feedback once I ask the testers about the codec. Regarding the comparison with DV film: CinemantiQ does color processing , lens simulation, etc. DVFilm is just (as far as I know) 24p converter. Once 1.1 version is released you will be able to compare the quality of our 24p converter.
Hornady,
Cinemanti
Old June 4th, 2006, 11:14 AM   #54
Nick,
Hornady,
CinemantiQ is an 8 bit app, for the moment. It will do scene spitting in a future version. It does not use GPU acceleration since the average user benefit was estimated to be marginal. It is pretty fast.
Old June 4th, 2006, 06:35 PM   #55
The software seems absolutely impressive. However, I live in PAL-Land and I presume the application is NTSC-only?
Alexander Benesch is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
