various Magic Bullet questions - Page 2 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old March 14th, 2004, 12:30 AM   #16
Hawaiian Shirt Mogul
what shutter speed did you use on the orginal tapes ?
some shoulder size camera's are set to 1/100 which will give you slightly more "strobic" feel then 1/60 ...
if by chance you had the shutter on auto then that would take experimenting in MBullet
Don Donatello is offline   Reply With Quote
Old March 14th, 2004, 09:00 AM   #17
I´m not sure I used a 1/60 footage. Almost sure I didn´t. If the shutter is fast it can cause stroboscopic effect? The faster the more stroboscopic it gets?
lml
Gustavo Godinho is offline   Reply With Quote
Old March 15th, 2004, 02:25 PM   #18
the higher the shutter speed, the more it will mimic film jutter, yes.
also, the more quickly you pan/move the camera, the more jutter you will see.
Adam Burtle is offline   Reply With Quote
Old April 15th, 2004, 02:44 AM   #19
Magic Bullet Suite v1.5, filter order
Hi,
Had a chance to play around with MB and it looked fantastic... just a bit curious of the order to apply the filters
I used them like this
(Top to bottom)
1. Deinterlace ( MB )
2. Film Look
3. Broadcast colors
If I moved MB deinterlace from step 1 to 3, all other effect "vanished" - no big deal, but I'm curious of why?
The current AE version of MB is quite expensive, do we have any price indications of the new "stand alone" version?
// Lazze
Sony HDR-CX130,Canon 5DMKII,i7 930@4.0, 12gb memory, 3x SSD + 2x1Tb(stripe), Geforce 480, Dual 24", Win 7 x64
Lars Siden is offline   Reply With Quote
Old April 15th, 2004, 10:36 PM   #20
Magic Bullet needs to be the top filter in order for it to do its thing. It gives you that little tidbit of info in the info panel if your filters are misarranged.
Your filter arrangement is correct. If you add any other filters I would sandwich them between the broadcast safe and the looks filter. That just seems like the common sense way to arrange them.
Eddie
Edward Natale is offline   Reply With Quote
Old April 15th, 2004, 10:48 PM   #21
Space Hipster
Magic Bullet and low grade VHS video
I finally got around to posting a short film I did with Magic Bullet 1.5.
The short was originally shot with a GE VHS-C camcorder in a few hours back in 1993 - the camera lacked any manual controls of any kind. It was shot in camera (rewinding the tape for each "edit").
It lay in a drawer until last summer when I restored it (the tape was failing in a number of places).
I added a new narrative/experimental layer, a complete 5.1 score and used Magic Bullet, Film FX and lot of AE effects to completely alter the look of the orginal footage.
It's screened a couple of times on a 20 FT screen with nicely shot 16mm but still got very postive feedback about the imagery, much to my surprise.
Downloads at http://www.sevensmilingshark.com (film is the second listed - "The Golden Girl and Sea of Tranquility".
So don't throw away that VHS cheapo junker just yet :)
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old April 19th, 2004, 01:55 AM   #22
Link didn't work.
Dave Largent is offline   Reply With Quote
Old April 19th, 2004, 04:50 AM   #23
Space Hipster
Typo - oops! Thanks for noticing. It's http://www.sevensmilingsharks.com
stephen v2
Old April 30th, 2004, 11:50 AM   #24
"The Office" how do they get that look is it magic bullet?
Does anyone know
1. What do they shoot "The Office" on?
2. I know they go through some sort of Deinterlacing program so What settings would you use for Magic Bullet and What way is best to light for that?
Rob Sibley is offline   Reply With Quote
Old April 30th, 2004, 03:13 PM   #25
This is the BBC comedy? (which is absolutley brilliant in my opinion) anyway - it'd most likely be shot on a PAL camera so they wouldn't need magic bullet or anything - from memory I don't think it looks progressive or deinterlaced - just reasonable quality video -- on one of the DVD's there's a making of discussion with Ricky Gervais and Steven Merchant but I think that's more to do with the artistic side of it than anything technical. There is a BBC web page for it - they might have more info
Scot
http://www.mango-a-gogo.com
Scot McPhie is offline   Reply With Quote
Old May 3rd, 2004, 04:25 AM   #26
Most BBC stuff is shot on digibeta. The sitcoms are usually just interlaced (I guess that applies to The Office). They shoot some of the drama stuff on digibeta and adjust shutters and route the signal through things that make it semi progressive. But most of the drama is shot on super-16mm.
Martin Munthe
VFX Supervisor/DP/Director
Martin Munthe is offline   Reply With Quote
Old June 11th, 2004, 10:02 AM   #27
Magic Bullet or DVFilm Maker? Slow x Fast.
FOR 1/60i to 24p JOB:
Magic Bullet is slow rendering, DVFilm Maker is very fast. The incredible difference makes DVFilm Maker a better choice? Or the video quality is so different (MB´s advantage) that I should be a little patient and get used to loooong hours of rendering?
lml
Old June 16th, 2004, 07:14 PM   #28
REALVIZ Retimer vs Magic Bullet - a test
Hi all,
I did some quick tests that don't prove much, but might be of interest to some. I took some interlaced 50i miniDV footage of me grabbing a juggling ball, processed with the following methods and cropped in Photoshop (and magnified so we can see what's happening easier)...
Original frame grab, interlaced (yuck!):
http://users.bigpond.net.au/spoonyau/BallOriginal.jpg
Magic Bullet in AE, default setting (No Deartifacting, Detail 4):
http://users.bigpond.net.au/spoonyau/BallMB25fpsdefault.jpg
Magic Bullet in AE, Deartifacting ON (default Detail 4):
http://users.bigpond.net.au/spoonyau/BallMB25fpsdeart.jpg
Magic Bullet in AE, Deartifacting ON, Detail 1:
http://users.bigpond.net.au/spoonyau/BallMB25fpsdeartdetail1.jpg
REALVIX Retimer in AE, using suggested settings:
http://users.bigpond.net.au/spoonyau/BallRetimer.jpg
IMHO the Magic Bullet default in this case wins, but we still have horrible interlaced artifacts - see the red dot on the ball.
Anyone have any better methods? (I know going from 60i to 24fps is a bigger and hairier monster - 50i going down to 25fps gives a nice filmic look without having to lose/merge frames)
By the way, when I watched the processed footage on a TV I couldn't tell the difference between them - they all looked great compared to the horribly-real-world-smooth 50i video yuck.
PS - nice DOF created by taking the camera further back and zooming in on subject, a nice little trick, and FREE!
Doug Turner is offline   Reply With Quote
Old June 17th, 2004, 07:59 AM   #29
Deinterlacing is always degrading to the footage. There is no way to create something that can compete with true progressive from an interlaced source. IMO Magic Bullet with deartifacting switched on does the best job.
If you shoot progressive to start with you're going to save weeks and month of rendering and your result is going to look much better.
Martin Munthe
Old June 17th, 2004, 08:50 AM   #30
Shoot progressive is faster? You mean shoot in 24p with the DVX-100 or shoot 30p with one of the cameras that do this job and after turning into 24p with MB?
lml
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
