How to animate maps in FCPX at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old August 31st, 2015, 11:35 PM   #1
I am grappling with two problems. Am wondering how to animate/highlight certain areas of a map in FCPX. I need to show some points of presence in a map say offices in 10 states.
Similarly how do I trace the route from Point A to Point B to Point C in FCPX? Are there some FCPX plugins that I can use?
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old September 1st, 2015, 01:09 AM   #2
Re: How to animate maps in FCPX
Might help - Getting iMovie world travel maps into Final Cut Pro X the easy way
https://www.foxvideo.co.uk
Dave Farrants is offline   Reply With Quote
Old September 1st, 2015, 09:49 AM   #3
A really useful application that coordinates with FCPX, and that can do what you want to do (and so much more), is Motion 5. And the good news doesn’t stop there, it costs only $50 (in the US), a real bargain.
https://discussions.apple.com/commun...tions/motion_5 then type in “animate map” (or what ever you want) in the query box. The same with youtube, search with the term “Motion 5 map” and it will yield some info.
Old September 2nd, 2015, 07:41 PM   #4
FXFactory Ripple Jumps plugin maybe
https://fxfactory.com/info/ripplejumps/
Ripple Callouts also has something that show from point A to point B travel.
https://fxfactory.com/info/callouts/
Old September 3rd, 2015, 03:40 PM   #5
Originally Posted by Dave Farrants View Post
Where does one find the maps to begin with?
Ed Roo is offline   Reply With Quote
Old September 3rd, 2015, 03:53 PM   #6
Ed - Maps are included in iMovie. Not only maps like road maps, but there are an assortment of globes, or space-view of Earth, and it can rotate. Hence, if one wants to show a long distance, such as San Francisco to London, the animated rotating Earth is a good option.
Using Motion 5 one can trick out the rotating earth with various effects. It’s amazing what creative tools are available but it does take some time to figure everything out.
Old September 3rd, 2015, 07:41 PM   #7
My copy of iMovie (10.0.9) doesn't seem to have any maps included?
Is there a specific location I should be looking?
Old September 3rd, 2015, 07:57 PM   #8
Yes, once you are editing a Project you'll see Maps & Backgrounds at the lower left under Content Library. It's there along with Transitions, Titles, etc. Click that and you'll see all the various maps. Just drag the one you want to the Timeline (or select it and press E to add it to the "end" of the the Timeline.
David Dixon is offline   Reply With Quote
Old September 3rd, 2015, 11:50 PM   #9
I had never thought of checking iMovie. Will definitely check it. Will try to download the motion5 as well. The Ripple Jumps seems to be interesting and can be used for a specific task.
Old September 3rd, 2015, 11:58 PM   #10
There is a 'stand alone' program that works well on OS X - Home Movie Maker Companion
2 paid versions, full export option, some maps included but would work with any open source (royalty free) maps.
Old September 4th, 2015, 10:56 AM   #11
Just a heads-up on Motion …
Originally Posted by Sabyasachi Patra View Post
Will try to download the motion5 as well. .
Motion 5 has a LOT to it. The application, for what it does and that is a lot, is, I think, really cheap. However, there is a really steep learning curve with getting to use it. While there are on-line courses available, these can be expensive. As an alternative, a tutorial book combined with on-line videos will be very helpful.
Since you’re interested in maps, one place Motion will be helpful is showing a route between two places, and showing an animated line as one would travel it (with all the crooks and bends, not straight as the crow flys) over time.
Unfortunately, a good book will cost as much or maybe more than the application! The book I used was Motion 5 by Spencer but this was written for 5.0 and there has been numerous new versions since then.
Old September 4th, 2015, 02:58 PM   #12
Mark Spencer also has online video tutorials for Motion just in case you find books daunting.
Getting Started in Motion 5 | Ripple Training
Craig Seeman is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
