What is the inherent resolution limit of FCP 6.0?
Hi all. . .
I have a RED One camera on the way, but someone has informed me that FCP 6.0 has a 2K resolution limit. Is this really true? And, if so, is there anything that can be done to allow me to shoot 4K, 4.5K footage on the RED? I'd like to use the camera at its best if possible. Any thoughts? Thanks much. Stephen |
Keep in mind, that no software-based editor can handle raw 4K footage - yet. FCP can easily handle 2k and routinely does such as the projects we've shot on the Viper, which outputs a DPX format at 4:4:4, 2k resolution.
Even at 2K, you're going to need a machine with as much horsepower as possible and a very fast external RAID array (SCSI or Fiber only, eSATA won't be able to keep up) pumping out a minimum of 250Mbs to keep up with multiple streams of 2k footage. Even with all that be prepared for long renders unless you have a SAN environment and a distributed network of CPU's crunching your edits. REDCODE will convert the camera raw into literally anything you want or need but right now the practical limit is 2K. Your software guide that will come with the camera will show you in detail how to handle your footage based on the system/format you're wanting to edit in. |
There's really no reason to edit at 4k. Work with 2K or 1K proxies. You can edit the 4K material that way.
Even for color grading Hollywood movies, it is done with 2K or 1K proxies. To quote Michael Most on the reduser forum... http://www.reduser.net/forum/showthr...7647#post77647 Quote:
