FCP 6 Smoothcam issue
I don't know if this is common for everyone, but I applied the smoothcam filter to a 2 second clip on my timeline, now a window has appeared that says SmoothCam Analysis...Analyzing "clip 1"...Estimated Time: 2 hours.
2 hours for a 2 second clip? That seems a little excessive. Am I not doing something right or is this filter simply impractical? |
The advantage (in my opinion) is that smoothcam runs in the background, so you can continue working on other clips on that project. Normally, I try to submit several smoothcam jobs in the evening and then leave the machine chewing on it. |
Are the filter presets decent or does it have to be tweaked? I would really hate to have to wait 2 hours each time I make an adjustment to it.
I'm using a 2.66Ghz quad core MacPro. The footage is DV25 shot 16x9 anamorphic. I'm already a half an hour into the process and it's still saying 2 hours. If your dual 2.3GHz G5 can process a 10 second clip in an hour, then why do you think it is taking so long on my system? |
Hi John,
It sounds like the entire clip is being analyzed, not just the portion you have trimmed down that is visible on your timeline. You need to make a new self-contained clip of the portion of the master clip that you want the smoothcam to work on and apply the smoothcam filter to that. I would add handles to the new clip so you have a bit of wiggle room. I'm not sure if making a new subclip will entirely break the association with the master clip, but exporting a full-rez version of the new clip and bringing that back onto the timeline will do it. Best, Simon. |
You'll still have to do a quick render of the effect for tweaks after, but it's nothing like the initial wait. |
I see. That makes sense.
I tried it and sure enough that worked. So even though I'm applying the filter to only one clip on my timeline, it has to process the entire raw clip? I think I'm going to delve into Motion a bit more for this kind of work. Thanks for your help Simon. |
Not sure if Motion will give you tools for smoothcam type work, John. If you want a better Smoothcam engine then try out Shake, which is where the FCP smoothcam filter originated from.
Best, Simon. |
the new version of motion has a stabilizer thats pretty quick. used it over the last 2 days to smooth out several aerial shots I just did. maybe not as good as smoothcam, but hours and hours faster. also, if the first pass from the motion stabilzer doesn't totally smooth it out, you can always run a 2nd pass. that said, its about the best thing I've tried in a long while, and I pretty much have everything.
Thanks for that info, Steve. I'll check out the Motion engine.
I've got a lot of slightly shaky footage that needs smoothing (the result of using a long lens on an overloaded tripod head). Best, Simon. |
SmoothCam
I just export the clip I want to apply SmoothCam to as a self contained quicktime file and import that file add it to the time, so it only analyzes the smaller clip. Works for me I might have 1 or 2 10-15 sec clip I may need to apply smoothcam to it only take 2-5minutes.
Basically what Simon posted b4 make sure to leave handle on the clips. |
