Slight change needed to individual clip after multiclip
Hi Everyone
Hope all is well with you all. I have a question for the multiclip now it alls out there. I have 5 cameras that I have used for a concert and have grabbed the footage for a multicam session. After setting the in points with the only thing I have to sync up with (usually a sound like an applause) I check out the sync of all the 5 clips. Sometimes one or two might be out by about 5 frames or so. Is there anyway I can trim the clip a few frames left or right so it matches up with the other frames from within the multiclip window showing all the clips. Currently, I have to go back to the offening frame in the browser, change the in point of the offending clip and then re make the multiclip. This seems a bit of a long winded way to do it, is changing clips from within multiclip window possible Thanks Andy |
If any one is interested, I came across the answer whilst surfing the net.
To make a slight change to an individual clip in a multicam set up click on file to select press and hold - ctrl and shift move the mouse over the footage you want to change click and move left or right to move footage start and end point |
Thanks, didn't know that either. I'll give it a try.
