FCP 5.1.4 crashes on any kind of HDV export
I left PP towards Mac & FCP about a year ago because I experienced so much misery on PC with drivers, crashes, the overall HD-support in Adobe... and now it seems to start over again.
Ever since then, I finished about 7 projects in FCP, I don't say there was never a problem, but I finally could solve everything. However, now...? On a pretty much standard Mac Pro, 2,66 quad core Xeon, 2GB Ram, running Tiger 10.4.11, I finalized an HDV project in FCP 5.1.4. FCP, set up in a standard mode, no specialities (except maybe a few third party filter plug-ins). The project is a documentary video, about 1 hour and 10 minutes long, in 1080 50i ('European' HDV). 7 videotracks, 6 audiotracks, the correct sequence settings, wuith a number of pre-rendered motion inserts (not natively inserted in the timeline, also rendered in 1080 50i), a few stills (maybe 15), but the major part native HDV footage 1080 50i, and AIFF audio files. At the beginning of the motion inserts (each time a chapter introduction with a map), I used compression and chapter markers. I came down from multiple timelines, to only one, containing all material and deleted the old ones. That's all. Editing is as it should be, no open spaces, no funny timeline constructions, also nothing exceptional running in the background. At first glance, FCP is working fine, the project timeline is fluid, no issues. First thing that went wrong, is that I couldn't perform a complete render. With the render mgr, I deleted the render files, same issue. But on purpose selected render actions of the timeline work perfectly. Every export that I do - whether it is QT, Conversion, Compressor to HDV 1080 50i starts, and then crashes. Funny: it never seems to be at the same place: sometimes a few %, sometimes 50%, but nothing goes down to the end. I also tried to make MPEG2 M2T's with compressor: same behavior. I tried everything: copying over of everything to a new created project. I tried via the media manager to export to a new project, same issue: crashed underway. Anyone a suggestion? Are stills (jpg's made from old pictures) maybe funny material? Or is the QT render engine from motion producing not fully compliant interlaced 1080 50i? Or can sequences go so corrupt you cannot recover them? I hope that upgrading to 6.0.X is not only answer, since I at least want to wait till 6.1 appears on the radar. |
Additional info
I've been to litteraly everything.
When I use the compressor export, I get a "Failed: 3x Crash Service Down" error. On the internet, I see I'm not the only one... but no solutions there. Anyone having a clue? |
