Burning to external burner with DVDSP4
I damaged the case on my MBP and its not physically possible to insert a disc to the internal burner. I've tried it on a fairly anceint external Lacie, but DVDSP keeps telling me to insert recordable media which already has been. I am able to play back on this unit on my MBP and also burn on my anceint G4 so I know there's nothing wrong with it.
Am what I'm trying to do possible and if so, how? Thanks |
If you are NOT getting this prompt, open System Prefs and go to CDs & DVDs, and make sure that "When you insert a blank DVD:" is set to "Ask what to do" |
I am getting the prompt. The first time I already had DVDSP open so I selected the finder. When that didn't work, I closed DVDSP, reinserted the DVD and when prompted, selected DVDSP. Same result.
So in other words, the MBP is recognizing both the burner and the dvd, but DVDSP is not. |
This is actually a flaw in the design of DVDSP. What you have to do is instead of clicking on "burn", you have to click on "build and format", and it will give you a bunch of advanced options. If I remember correctly, it has a drop down menu giving you the option of which ever burner you want to use on your computer, or to make a disk image. Anyway, you can just choose your external burner and everything should be fine.
Chris
Thanks for that. Actually I managed to find that very answer on another forum though I found I still could not burn it directly. I had to save it to disc and then use disk utility to do the burn. |
