MPEGSTREAM: MPEG2TS to Final Cut supported format
I am using Canon Console software to capture footage to my notebook. The problem is that Canon Console records the footage as MPEG2TS. This format is unsupported by Final Cut Pro. If I want to edit the footage I capture with Canon Console, I have to covert it to a Final Cut Pro supported format.
I have been looking for a good application and I have two candidates: MPEGSTREAM and HDLINK (Cineform). I think the best solution is MPEGSTREAM. My question is: which settings should I use to convert my MPEG2TS (shot with Canon XL-H1) to a Final Cut Pro supported format? Compression: ? Framesize: 1920x1080 Quality: ? Framerate: ? (I guess 50 for 50i and 25 for 25F) Then they have deselect for progressive movies: Interlaced scaling Reinterlace chroma Deinterlace video The first two are checked by default. If I add this to my workflow, I want to make sure that the converted files are not degraded in quality. Who can give me some advice? |
I do not see the Apple Pro Res option. I do have Final Cut Studio 2 and do have Apple Pro Res settings within Final Cut. What about the audio settings? They are on uncompressed by default? Should I leave them like that?
Strange, it should be there.
Yes, audio should be uncompressed. |
I found it now. I see "Apple ProRes" two times. The first is the high setting and the second one is the normal setting.I tried Apple Final Cut uncompressed but that was 1100 Mbps which is a bit too much. 4,5Gb for 36 seconds. Ai.
Thanks for your help. The Apple HDV 1080i50 setting creates a 113Mb file where the MPEG2TS file is around 116Mb. So that seems to be the matching quality with the Apple ProRes as high-end alternative. And I see that there is a Cineform setting which might come handy in projects where I work together with people that are editing on a Windows platform. |
Hi Floris
Why are you using the CONSOLE app to bring in your footage to your notebook? Can you not capture the footage directly using FCP? Using FCP's Log and Capture you have the option to capture directly as native HDV, or transcode in realtime during capture to Apple Intermediate Codec (AIC) or Apple ProRes422. Unless there is a special reason otherwise I would respectfully suggest you are pursuing an overly complicated workflow. Hope it helps Andy |
-gb- |
Fair enough Greg, though "if" Floris is using it simply to capture then it does seem that it may be creating more problems than its solving on this occasion.
Just did a bit of digging and the software sounds pretty impressive though. We're getting a bunch of the XL-H1's soon so I guess I'll be trying to sneak the Console app to the budget! best Andy |
The biggest reason why I use the console application is that my notebook is not a Macbook/Macbook Pro but a high-end Asus laptop. I started out working with Adobe Premiere on a PC/notebook. That resulted in a lot of problems which made me switch to Apple/Final Cut Pro. However, after buying a Mac Pro I had not budget to exchange the laptop so I still use it.
Canon Console however is a great program where you can basically control the whole camera (except for the ND filters). It is great for setting up a shoot and it also gives you a proper focus monitor (XL-H1 LCD is way too small/dark). And the Waveform/Spectrum meters in Canon Console are very handy. So capturing in Final Cut would be an option, but not possible. And I must say that the conversion in MPEGSTREAM goes remarkably fast. |
