Capture problems with FCE?
I'm having problems capturing footage through Final Cut Express. I'm still not sure if it's a problem with my camera or with my hardware/software, I'm guessing it's the former, but I want to make sure. I'm using a MacBook Pro with a 2.44 GHz Core 2 Duo and 2 GB 667 MHz DDR2 SDRAM running OSX v. 10.5.1. I've used both Final Cut Pro/Express before (not on this computer) and never had any problems. Are there any preferences that I need to change around, or anything like that to try and get the camera to export? I know both firewire ports are working (6-pin and 9-pin) so I don't think that's the issue. Any tips?
Thanks. |
I didn't really catch what your problem is exactly? Can you not see your footage in the log and capture window at all? If that's the case look for your DV in/out on your camera and select out.
I used to have this problem sometimes where everything was set right, and after turning the camera off and on and just looking around it would work all the sudden. Even though I didn't do anything -so check your camera settings again. Or state your problem more clearly. |
-Alex |
So it's when you start final cut that it warns you there's no camera? That seems to me that it would be the camera settings. All I can think of is to fiddle with the camera's dv out, and click check again.
It has helped me sometimes after checking my settings, to hit play. finalcut has recognized the camera simply from that in the past. Otherwise you can check your "easy setup" in FCP to dv again. Assuming you are going in with a dvcamera and a firewire. |
