5.1 Surround Sound
Alrighty, I have it setup in FCP 6 correctly I believe, the 6 audio tracks with it going to the different speakers etc. Now, how in the world do I make it work when I burn it to a DVD. I tried DVD Studio Pro and Toast and was unsuccessful in both attempts. I tried searching but I haven't stumbled upon the right solution. Any help would be greatly appreciated.
Thanks Jason Rookie FCP Player |
You create an AC3 file using Compressor. I don't know how to do that directly from Final Cut Pro; what I do is either
- mix my surround audio in Soundtrack Pro and export from there, or - export individual audio files (one per channel) from Final Cut Pro Then take the audio files and drag them into Compressor's 5.1 audio panel - out comes a single .ac3 file that you can import into DVD Studio Pro. Sorry, not the most verbose instructions, but I hope this helps point you the right way! - Martin |
I'll give it a shot this afternoon...I'll let you know how things went!
Thanks |
So I got the 6 tracks out from FCP to Soundtrack Pro to Compressor and followed all the directions on Lynda.com but...
I must have missed a step somewhere, it did not work when I tried to burn the dvd to DVD Studio and Toast. If someone out there is bored and wants to write down an easy step-by-step process I would love them forever. I'm not producing any major movies or anything I just want to know how to do it in case I need it one day. Thanks for any and all help |
| All times are GMT -6. The time now is 01:03 PM. |
