DVDSP says "Video Bitrate Too High", but why?
I've managed to get my multi-angled tracks' GOPs conformed, etc... now I am getting a "Video Bitrate Too High" message upon building my DVD.
V1 = 4,998,041 (or 4.76 Mbps) V2 = 4,994,258 (or 4.76 Mbps) V3 = 5,001,921 (or 4.77 Mbps) There is one audio stream, a 16-bit/48k AIFF with an average data rate of 1,536,000 bits/second (or 1.46 Mbps) According to the DVDSP (4.1.2 is the version I am using, FYI) user manual, on page 70: Quote:
What do you think is going on here? |
Remember that when using alt-angles that the total amount of data per track has to be accounted for included the angles. A max bitrate of 7 is too high, try a max of 6 to 6.5 with an average of 5.
Get the Apple Training Series DVDSP4 book; you'll get all the answers and troubleshooting tips you need. |
Don't know why, but...
Replacing the AIFF audio streams with their AC3 counterparts solved the issue. However I still don't understand why it was telling me the video bitrate was too high. It's not making sense.
@Robert: that book is certainly on my shopping list! |
DVDSP4 while not 100% able to author every aspect of the DVD spec is built around the DVD/ISO specification which, by preference wants to see a compressed audio codec for proper playback. In reality, your build with AIFF's *might* have played fine on newer players, DVDSP4 knows the limitations of the ISO spec and has built-in limits to prevent a bad build-out. I've seen in extreme cases where code-monkeys have hacked DVDSP4 to lose the various warnings when bitrates get too high in an attempt to maximize playback but they almost always create playback issues with most set-top DVD players. In short, DVD audio needs to be 2 things for both a good encode and for proper sound: it needs to be the AC3 (or other compressed format allowed by the DVD spec) and max/peak levels need to be preset in editing at -12db. (You can also use Compressor's built-in audio filters to bring the audio down to the -12db level if all your FCP sequences were edited with audio peaking at maximum.) Trust me, once you get the book you'll have so many "I didn't know that..." moments you'll wonder how you ever got along without it. |
OK, here's another one for you. I have a successful build, burned fine and plays well in both my Samsung and Panasonic DVD players (and fine on both Macs through DVD Player). The only oddity is playback on the Samsung, one of the tracks (the same one, every time) seems to skip a bit as if it was playing back at 2x speed. Not in the Panasonic, not on the Macs... so I am leaning to assume it is just my one DVD player acting up. The section of the disc where the section of data lays is about the middle of the disc, not either inner or outer rim, and there are no scratches/dust/fingerprints/etc. I don't know what to do to further debug. I've never seen this before. And I am a bit nervous about sending in my DDPs to the replication house if this is going to turn up on other people's players -- I know there's always the possibility, but I want to make sure I CMA (Cover My A**). |
It could be that's where your layer-break is? Try using different media for the burn; Ridata and Verbatim seem to be the media of choice.
Also, the Pioneer DVR-112D or newer seems to be the best DVD burner for the Mac (many MacPro's shipped with that as the Apple-branded SuperDrive). Unless you've got DVDAFterEdit to help you check the proper build of the actual DVD image there's no way to know exactly what is causing the skipping, but try the above and see what happens. |
Verbatim DVD+R DL is the media I am using with an external LaCie FW drive (my Mac came with the combo drive... I'm on a dinosaur dual-867 G4 MDD). Quote:
When I make demo discs for clients that are very short, I have created some presets at 7.2Mbps but due to the VBR scheme that Compressor uses I must use AC3 audio since AIFFs will require too much data for the DVD standard. I have yet to experiment with higher CBR compression in the new version of Compressor. |
It's important to know, that the only reason AIFF/CDFF files can playback from an MPEG-2 stream is because DVD players are designed to also act as stand-alone audio playback devices - a built-in CD player if you will, hence the actual DVD ISO image will technically support having an AIFF in the track. However, DVD players were never optimized to have uncompressed audio *alongside* a video track which is why the AC3/Dolby compression format was created almost 20 years ago. This same scheme applies to the Blu-Ray spec; while bitrates are significantly highly for BR both in audio and video compressed audio is still the authoring standard, period. |
That's interesting information. AIFFs encode much faster than AC3 which is why I like to use them when possible (not much anymore).
I wonder why Apple chose to not have a 60 minute preset in Compressor 3. Standalone DVD recorders manage to get around 9Mbps video tracks so it would be nice if I could coax something like that from Compressor. |
- Martin (*) "compression" as in "reducing the size of the data", not "reducing the dynamic range of the audio" |
My old Panasonic DVD recorders made MPEG2 and AIFF audio files at all bit rate setting. I know this since I regularly demux the DVDs for other projects. My newer JVC DVD recorders record in AC3 for all settings. These recorders make MPEG2 video files that have higher bit rates then I can get out of Compressor. Anyone have a formula for Compressor to get the highest video file bit rate possible? |
Without knowing the model number you're most likely referring to the combo models that have DVD-VHS-MiniDV built in? Those recorders are designed to capture and record *tracks* not create a fully authored disc with menus, subtitle functions, alt-angles etc.
Important too, is that since those devices burn tracks only bitrates can be higher all around. Compressor nor any other software-based encoder can replicate what a hardware encoder can do, which is what you've got in those combo machines. In fact, if it were possible (and it's not, so don't worry about trying to figure out how) to take these hardware encoders and grab the MPEG-2 file it creates and then import that into DVDSP4 you'd have a superior looking output. That's why anything encoded with Compressor, BitVice and other software-based engines will never look as good as what the big Hollywood studios output does - because the studios are *always* using a hardware encoder to create their MPEG-2 and AAC/AC3/Dolby compliant files, period. If you really want to maximize your encodes, get an XP-based machine and purchase one of the few hardware MPEG-2 encoders and use those files to import into DVDSP4. They're not cheap but currently there's nothing that compares to a good hardware-based encode. |
