HV20 output to HD Cam
My client wants footage delivered on HDcam. I shot about an hour with the Canon HV20 in the cinemode (24f). I have a post house using Final Cut (same as me) that will output to HD Cam but I am unsure what exactly to deliver.
I usually capture in the 108024p - Easy Set Up, which captures the HV20 footage to 29.98/1080i60. Can I drop the footage into a 1080i60 timeline and make a self contained QT with the those settings, have the post house import my quicktime on the same timeline and output? Or do I need to remove pulldown before I output to HD Cam? Thanks. |
Never seen that workflow, ever.
Best thing to do is ask the post-house this question, that way you're not guessing and their editors will get exactly what they need. |
thanks ben. question is do i need to process in prores? could I output a self contained 1080i60 QT and transfer that to the HD Cam? remember the footage shot on HV20 was in 24.
Good question- no you don't need to process in ProRes, we do it for the gain in color space but you might be doing the post house a favor by giving them something intraframe and not HDV. They will tell you if they can take an HDV file. Re. pulldown, sounds like you can leave it as-is for an HDCAM transfer but you may want to double-check on how the client wants it, for their purposes.
