Green frames after putting subtitles...
I'm laying down French subtitles over English subs and covering the English with black. I am getting green pixels all over the image mostly at the beginning of the new subtitle text box on the timeline in FCP 6.
I did start with a source file ".m2v" that is NTSC. I then created a new sequence in PAL and I lay the .m2v file and then rendered and was able to play it. I then put the new subs down on the PAL sequence. Wondering if anyone knew what is causing this. Thanks for any help. Also, when I export it at "current settings" it should export as PAL so I can make a PAL DVD correct? I am also getting out of sync audio in different scenes, not all of it... MAC G5 Leopard FCP 6.0.3 |
Is it the correct way to work on an NTSC timeline since the source is NTSC, do the subs in NTSC timeline, export, and THEN do a conversion using Compressor?
The NTSC export was fine. I went to Compressor to convert to PAL and I got the green pixel frames and the movie is out of sync.
Life sucks :) |
