Export to Flash
Since I'm new to the Mac side of things, I'm having to find new pieces of software here and there. What do you guys use to export/convert a video to Flash? I was using a program from Moyea that would let me convert to flash in just about any resolution/bit rate and it would also convert the frame of my choice as a .jpg for the website. Any thoughts?
Thanks, Chad |
If you have Adobe Flash you can use the included Flash encoder.
I use the free download ffmpegX but make sure you install the additional components for the flash to play properly. You can also just upload your video to facebook, youtube, vimeo, etc., let them encode it and save the file back to your desktop later. If you want to watch flv files in Quicktime download and install the Perian component. |
thank you for the tip, It works just be using ffmpegX & Perian
I use Sorenson Squeeze
export to quicktime video.. then use visual hub.. great program that will convert video to whatever you pretty much want, including flash.
