Final Cut Express Capture Problem
I'm supposed to start editing our no-budget indi-flick that's shot on the xha1 in 24f, but it's not capturing properly through Final Cut Express. I have it set up for hdv 1080i60 (no 24 frames in Express).
Every time I try to capture the footage, no-matter which tape I use, the preview is super-choppy and then pauses about 15 minutes into the capture (I'm not sure if the actual capture continues, but the tape keep playing through the camcorder). When it finally reaches the end of the tape, or if I stop it, Final Cut becomes unresponsive and I have to restart the computer. The capture files are on the computer, but even a tape with 30 minutes worth of footage ends up splitting into about 50 individual video files, all with the audio out of sync. It does the same thing if I try capturing the tapes through my hv20. Any suggestions on how to fix this? If not, any recommendations for dedicated capturing programs? I'm in a bit of a hurry to piece together a teaser. |
I'm quite surprised that you can even capture the 24f footage into a 60i timeline. In any case, I think results would be very questionable as the timing is not compatible. That's why the audio is out of sync in your clips. With the HV20 it's the same thing if you play back tapes that were recorded on a XH A1. The HV20 will then output true 24f, so you have the same problem. (However, if it's 24f shot with the HV20, it's actually embedded in 60i format so that would work.). Short answer is it won't work with FCE (except if the new v4 version actually supports 24f). I'm not aware of an alternative capture method. Dino |
Thanks for clearing that up. Looks like I'll be using Vegas for this project. |
