-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Green Check mark on Sequence window in FCP 6.0.3 (https://www.dvinfo.net/forum/final-cut-suite/125050-green-check-mark-sequence-window-fcp-6-0-3-a.html)
Paul Chiu June 30th, 2008 04:03 PM
I got this check mark in a small green circle inside a sequence window within FCP 603 and after wards, things are simply running slow or not at all.
what is this mark and how do i fix it?
thanks!
paul
Shaun Roemich June 30th, 2008 04:10 PM
The green check mark indicates that all your luminance values are inside of Broadcast Safe.
The third "radio button" from the left in the canvas window will bring up a drop down dialog. Uncheck "Show Excess Luma"
Scott Anderson June 30th, 2008 04:11 PM
This is an Excess Luma Check. Goto View>Range Chack>Excess Luma to switch it off. The same control can also be accessed from the rightmost of those 3 oval buttons at the top of the Canvas Window.
Having this on shouldn't slow down your performance, however.
Scott Anderson June 30th, 2008 04:12 PM
Shaun - Jinx, you owe me a Coke! Seriously, though - is there an official name for "those 3 buttons on the top"?
Edit: the right-hand button is called the "View pop-up-menu" this from the peachpit book.
Shaun Roemich June 30th, 2008 04:16 PM
Great minds think alike, or is it that fools seldom differ?
Paul Chiu June 30th, 2008 05:45 PM
thanks guys.
the manuals and the peachpit books may have covered this but i could not find it.
any good video series you guys recommend? for tyros, that is.
paul
Mike Barber June 30th, 2008 06:29 PM
Originally Posted by Paul Chiu (Post 901252)
for tyros, that is.
What's a tyro?
Scott Anderson June 30th, 2008 08:18 PM
It's a novice or beginner. I would recommend lynda.com's training, as you can ala carte by several different subscription plans.
If you're looking for a set of dvd's, I've had good luck with Total Training back when I was learning After Effects. They now have a similar subscription plan for online content, but only by the year.
I've actually found the Peachpit books to be very comprehensive, provided you go through the whole book. Not always the easiest thing to do when all you want is a nugget of information.
Actually, come to think about it, I've heard of this site called dvinfo. I understand folks are pretty friendly there :-)
Mike Barber June 30th, 2008 08:24 PM
Really? That's not what I heard.
;-D
So tyro = noob?
Scott Anderson June 30th, 2008 08:35 PM
OH, a NOOB....In that case, yeah - you're right.
Nobody likes a noob.
