M2t file => prores 422 on mac. And on PC ?
Hello everybody,
I start to shoot concerts that i will later sell to the musiciens to do their own editing. I will tell the mac people who use final cut to use mpegstreamclip to convert the files to prores 422. But for the people who work with Premiere or something eslse on mac, which format can i tell them to use ? And for the PC ones, in which format to convert, using mpegstreamclip ? Thanks. |
why convert ?
let them choose the format they need. M2T is almost universal today and is the most compact for distribution. (20 minutes will fit on DVD, 2 hours on a 25gig blu-ray). you can even just make a copy from tape to tape without loss. ideally you shoot with tape+hard disk device, you gave them the tape , you keep the copy on disk. |
I don't want to convert for them, i want to advise them which format can be good fo them. Because they are not editors, they are musiciens. Perhaps some of them had experience with dv, but few with hdv.
That's why i will give them m2t files on dvd because they won't have a camera like mine to make the acquisition of 720p/50. But i want to tell them a little bit the way they can do things. For the hard disk device, i will probably buy a nNovia QCHD Deck this week. |
What format to use will depend on their editing software. Some work on the native HDV files directly, some have a system for converting to another editing format, and some have both. For Premiere users the optional "Cneform" solution is a good choice, but it costs a few hundred for that software.
there's several hi-quality, multi-platform codecs available:
cineform sheer video are 2 that come to mind |
Is there something interesting and "standard" (like AIC or prores 422 (also this one is not standard and come with final cut) on pc, that can be used without paying extra codec (like cineform &sheer video, if i understand well).
I don't know if the people who will do the edit will be professionel or not. |
I downloaded and installed the trial of the latest Premiere for Mac and found that it didn't recognize m2t! Anyone else had the same issue?
The prores422 codec is only installed on a system with FCS2. I'm not sure about AIC (because I think iMovie uses AIC) but it may also require FCP 5 or newer for the codec to be installed. The best cross-platform codecs for quicktime that work in all applications (PC & Mac) are Motion Jpeg A or B and Photo Jpeg. |
trial version of premiere does not include HD.
Free codecs that support 10bit 4:2:2
thanks for the help, i did isntall both these codecs, how do i utilize them, in the sense, through vegas? AE? QT? thanks again |
Thanks. |
processing 422 on mac & pc
so if one even aquires video over usb to a format like mxf files from the Sony EX1, its much better to convert thse mxf files to a 10bit 422 YUV color space video if one needs to do extensive color correction so that there is no banding and that tweaking with secondary color correction yeilds better smoother deeper results, and ultimately the final output on DVD looks more hollywood like which obviously everyone wants, right??
