Jittery scrolling text in FCP
I'm using scrolling text in FCP for credits. The final output is very jittery. The text doesn't scroll smoothly. This was shot in PAL. Does anyone have any suggestions as to how to correct this?
Thanks |
perhaps the scrolling speed is to high? did you try to slow it and see the result?
or....can you give some more details? |
You're surprised that matting 30fps scrolling text over 25fps content is "jittery"?? I'd be surprised if it wasn't. Try transcoding your movie as a 30fps file. THEN super your 30 frame text over that. If that still doesn't help, try these things. 1. Use larger type fonts with soft drop or halo shadows (jitter is often the result of hard contrasty edges crossing scan lines) 2. Make sure check "sub-frame" rendering. (see the manual) 2. Use soft drop shadows 3. If nothing else works, apply a modest blur to the text Tell us if any of this helps. |
