Frame Rate change
Hi all,
I have a piece of video that is an animation that was rendered out of a 3d package.. it is 210 frames long, yet when I play it with the quicktime player it plays very quickly like it has only 4 frames of video,, I bring it into motion and using the inspector I see that it 7 seconds long, but the frame rate is set to 3000 fps.. I am able to scrube through it with quicktime player, and I can see all 210 frames are there.. but I cannot figure out how to change the frame rate to 29.97 fps ?? I tried Final cut, Motion.. Just could not figure out a way to change it..And suggestions on how to get the quicktime frame rate on this thing back to 29.97 fps ?? Thanks in advance ?? |
Have you tried bringing it in to fcp and creating a new quicktime file with the correct frame rate that you're looking for?
Hello,
I tried exporting it using compressor, to the animation codec.. which says it was set to 29.97 fps.. but when I compressed it was the same ,... |
I would suggest changing the clip speed in the timeline, but I think you'd have to put it in a 60p timeline, reduce speed 50%, export, then bring that into a 29.97 timeline and reduce again. My guess is someone forgot a decimal before they rendered the clip they handed off to you. I'd go back and see if they can re-render at the correct frame rate.
Can you export it from something as an image sequence and then bring the images into FCP with a still image duration of 1 frame and then render the timeline and export to a DV QuickTime? Ugly, but...
Mike
Have a look at the helper app QTSync: QT Sync 0.3.3 - MacUpdate Its a quite a gem for a number of functions (like adding an instant TC burn in) ... but what you might particularly like is the Edit > Change Movie Playback Speed option. Hope it helps Andy |
Andy, great catch! I won't try installing it until I finish the project I'm working on but QT Sync looks like a neat little tool.
Thanks guys for all the suggestions..
I took it into After Effects this morning.. and it looks like I can force it to chage the frame rate using interpret footage.. !! |
Anyone else try loading the qt_sync app??? How's it looking??? I'm getting some weird pixilation on the menus and such.
EDIT: Opps... it's fine... operator error. |
