FCP Settings for capture. Need help PLEASE.
I'm new to Final Cut Studio and need help setting up a working capture template and Audio Video settings. Also project settings.
Basically everything to get going. I have a Sony Z1 with everything shot in Pal HDV 1440 x 1080i. Final end product will be to DVD MPEG-2 I want to capture to the highest resoultion so should I use Prores? If so, this is where I need help getting set up. Seems to be many ways to do things and now I'm lost. Regards |
The long and short of it is this: no codec will add quality. What you want is maintain quality and make your workflow as easy as possible. I suggest you go to the Apple Discussion board for FCP and search for "HDV ProRes" and read the many informative threads. In fact, here's the link. Regular poster 'Studio X' puts it simply: Capture HDV, set the sequence renderer to ProRes. Another post I would like to quote is from Zak Ray: Quote:
Thanks Mike,
I was wondering can I capture through Firewire from camera straight to Prores as I dont seem to have this in my capture settings. I have the sequence render settings as Prores though. Something is up with the site today as i have posted also and nothing comes up. Simon |
Thanks Mike,
I cant see your question about technical specs? I use a MBP 17" 2.5 Ghz and looking at the Apple link you suppled the MBP cant do it. Regards |
I don't work with HDV, so I'm not exactly the best person to give you advice, but saw no one else was chiming in… hope I am more help than harm. |
