-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   16:9 to 4:3 in FCP (https://www.dvinfo.net/forum/final-cut-suite/139117-16-9-4-3-fcp.html)
Jack Davis December 7th, 2008 06:54 AM
16:9 to 4:3 in FCP
I normally work with 16:9 but I have project which 4:3 would be better. How do I change the viewer and canvas to 4:3?
Luke Oliver December 7th, 2008 08:18 AM
re
dont u have to click right on the sequence( not in the timeline but in the log bin) and choose settings???
Liam Hall December 7th, 2008 01:44 PM
Just make sure 'Anamorphic' is unchecked in the browser.
Cole McDonald December 7th, 2008 04:35 PM
I generally will make a new sequence (right-click/ctrl-click in the clips browser) and set that as a 4x3 sequence, then nest the 16x9 sequence in that, scaling the footage to fit the new aspect, then use keyframes and moving the clips in the canvas to Pan & Scan them to work with the new framing.
I also use this method to letter box my 4x3 footage so I can reframe my eyelines onto the top third line of the frame after the edit is done.
