DVD Studio 4 help
I know the answer to this is probably Really simple but I need help. I'm using DVD Studio Pro 4 to make a DVD. I have a a video track as the first play option and I don't want anyone to be able to skip past it. How do I prevent this?
For the track you want them to not be able to skip, go to the User Operations tab and disable the controls.
I did. I disabled all user options but it still allows you to skip the track and go to the menu.
Disable skip
Shaun,
Make sure you are in the advanced settings tab. Click on your track. Click on the connections tab. Make sure that "next" is blank and set the "end" field to what you want to play after your track. Hope this helps. |
