Need help ASAP: Stuttering H2.64
I'm trying to push out a project due tomorrow. Shot on EX-1 edit in FCS. I used Compressor to process to QT H 2.64. It runs and looks pristine on my macs. When I bring it to a Windows machine,the image is fine but the audio is not in sync. Equally crappy whether I run it from a DVD or copy the QT file onto the PC's hard drive.
I updated the QT player on the windows machine without any change in the problem. I'm stumped. The machine is capable of H2.64 as I have other, albeit smaller, clips that I've played. Yikes! |
I honestly don't have any idea what could be causing that problem, but there's a few things I might try.
The first thing to do would be to export a small clip of your video. Run that through Compressor and test it out on your different computers. That might tell you a little bit about what is causing the problem. Secondly, if you have no issues with the first step, then try re-compressing your entire video. Maybe something just went wrong the first time around. Good luck in delivering this for tomorrow! |
