compressor 16:9 problems
Hey Folks, I have an HDV 30p project in 16:9 and when I export it form FCPS to compressor using the H.264 codec it keeps converting it to 4:3. Does anyone know what I am doing wrong.
Thanks |
In the Inspector, go to the Geometry pane and, under Dimensions>Frame Size, scroll down to "Custom (16:9)" and select that.
Thanks David, I'm going to try that now.
Hey David, That didn't seem to work. Now if I export the video as a QT reference movie and import it into Compressor I have no issues. But If I export the video using compressor and continues to encode it as 4:3 ,I can't seem to get it to work. I'm using the Quicktime H.264 codec and tried a few different setting but still nothing.
did you set the width and height to values corresponding to a 16x9 frame size like 853x480?
You are the man, that worked great Aric.
Thanks Again Jason |
