Help! - JVC HD110, FCP, and 720p24 ingest?
It's really late at night and I need this answer quickly so I hope no one will take me to task for not finding a post about this (if it's out there).
For the first time, I have recorded some footage in 720p24 on my JVC GY-HD110. Now I am trying to ingest it into FCP6 but I get strange time code in my clips. I used the HDV 720p24 pre-set with a frame rate of 23.98 but the resulting clips have time code that registers frames past 24- seems like they go to 28 (weird??) but I am not sure it's consistently like that. It seems like a pulldown issue but I don't see in FCP where I can deal with it. Can anyone provide some help as to how I get my 720p24 tape ingested into FCP? Thanks so much. TVH |
That's right. FCP does that for some reason (it seems to number the frames against an NTSC frame count or something). It's still giving you 24 fps, just numbering it a little weirdly. If you want to know why, I think Tim Dashwood made a post about it.
But there's absolutely nothing wrong with your captured footage. Go ahead and edit it. |
Thanks...
Makes me wonder if I should have bought the Canon instead of the JVC? Grrr. Terry |
FCP does cut a few seconds off the beginning and end of a clip if you are running at default settings. Most just allow a few extra seconds of pre-roll and post-roll when they are recording. Then it's no sweat. However, you can adjust your FCP settings down to just one second pre-roll and one second post-roll. (In the Audio/Video Settings, go to the "Device Control Presets" and adjust Pre-roll and Post-roll to 1 second by making a new preset. The full steps have been given in a couple of posts.) Some like to capture through FCP directly as ProRes (or ProRes HQ) by going to Audio/Video Settings and selecting it in the "Capture Preset" drop-down menu. But the most "foolproof" solution, if you're having pre-roll/post-roll problems or even experiencing mid-clip breaks, is to capture with DVHSCap and then wrap the captured .m2t file in a QuickTime wrapper using ClipWrap. There's a sticky thread in the GY-HD100 forum explaining this marvellous application. DVHSCap is part of the “FireWire SDK 20” package and can be downloaded from this page (you have to scroll down to find it): Apple Developer Connection - Development Kits Another way is to capture as a QuickTime on a hard drive while you are recording, such as DR-HD100 or even one of the other FireStores (using ClipWrap). There might be a few other methods too, but these ones are all pretty good. |
