-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCPHD problems on G4 (https://www.dvinfo.net/forum/final-cut-suite/26683-fcphd-problems-g4.html)
Mike Avery May 28th, 2004 06:59 AM
I installed FCP 4.5 on my G5 and G4. It works great on the 5, but locks up and quits on my 4.
I capture video with no problem, but when I try to work with it (save, move, edit, etc), I get the spinning ball....then it quits.
It doesn't lock up or crash the whole system...just Final Cut.
Any ideas?
Mike Avery
Richard DuPree May 28th, 2004 08:13 AM
I'm having a similar problem. When capturing longish clips (30 min.) the spinning pinwheel of death won't stop when capture is terminated. I usually cannot force quit successfully (FCP just doesn't want to let go!!), so I must reboot. The captured file is entitled "untitled-av" and will not play as a standalone Quicktime file. I have given these problem captures up to 1 hour to complete their mysterious process but to no avail. Shorter captures seem to work okay.
Anybody out there have a clue? I need some help.
Jeff Donald May 28th, 2004 09:40 AM
Have either of you tried trashing the three FCP preference files?
Mike Avery May 28th, 2004 09:47 AM
Sorry Jeff,
First thing I did was trash those files. I also did repair permissions, though I'm not quite sure what that does.
Mike Avery
Richard DuPree May 28th, 2004 09:50 AM
Yes. Just did it. It works. Many thanks.
Jeff Donald May 28th, 2004 09:56 AM
Richard, I'm glad it worked and thanks for posting back.
Mike, yours is ounding more like an install issue. what OS (exact version) and QT are you using?
Mike Avery May 28th, 2004 10:00 AM
OS 10.3.2 and QT 6.5
FCP4.1 is still installed, it works fine.
Thanks Jeff,
Mike Avery
Jeff Donald May 28th, 2004 10:37 AM
Mike, unless you have a reason not to, I would install 10.3.4, repair permissions and see if that doesn't help. The combo updater is here.
Mike Avery May 28th, 2004 10:49 AM
No reason not to that I'm aware of.
I'll let you know.
Mike Avery
