Error Mess(age) 25
When I open a sequence in FCP 3.0 on my G4/400 PB (OS9.2), it crashes citing Error Type 25. What is Error 25 and is there anyplace that lists the error codes and their raison?
Oddly enough when I open an identical sequence from another project that contains only that sequence and then open the sequence I want to open, it opens. Thanks for any info, elmer |
I haven't used OS 9 in 3 years, but to the best of my memory, Error 25 is an out of memory error. How much memory on your computer and how much is allocated to FCP?
I have 768 mgs RAM and to FCP 3.0 I've have allocated 250000k minimum and 350000k preferred.
I heard 3.0.2 is more stable but at Apple Support I couldn't find the update. Know where I can get it? Thanks for the response, elmer |
Yeah, old versions of software are hard to find on the site... a MAJOR pain in the butt. Using search on the site though I found: http://www.apple.com/support/downloads/finalcutpro304update.html
Try setting minimum and preferred to 500000k and you should be good to go. The update should help also.
Thanks Mark & Jeff.
Unfortunately 3.04 is for OS X, and I'm using OS 9.2 and the update for that is 3.02, the one I couldn't find. I will set minimum and preferred as suggested. Thanks again, Elmer |
I found 3.0.2 here:
http://docs.info.apple.com/article.html?artnum=122009 You need 9.2.2 to run it... Always try going to the support section and using search. The basic search for the site didn't find it. Hope this helps! |
Thanks for the help. I found it.
I bet errror mess(age) 25 is referenced when the video card is overwhelmed. The project I can't open on my TiPB with 768 mg RAM will open on my G4/400 Desktop with half the RAM. When I closed the sequence on the Desktop, saved the project and reopened on the TiPB it opened. I believe the Desktop's video card is 2x the TiPB's. For this and a few other reasons over the years, I found having 2 computers a blessing worth every penny of purchase. que sera, elmer |
