short clips into one long based on TC
Hi all
I have a little problem to solve. I have concert recorded with 3 cameras, 2 of them recorded one continious shot, third camera was recording only short clips (cameraman wasnt recording all the time since he didnt have enogh media to record on) Now i'd like to create a 3 cam multicam clip with FCP. Since the TC was running on FreeRUN, it is possible to create a long continious clip off the 3rd camera material, based on the timecode. The caps will be filled with a slug. Right now, i'm calculating the timecode between the ending of clip A and beginning of clip B to have the right amount of slug and then I insert the clip B. Since I have about a 150 short clips, I wonder is there a easyer way to to that? Edit: I have found a little way to skip the calculating part :) I will change the starting timecode of the Sequence to match the first clip starting timecode, now I only have to copy-paste the starting timecode of the clips. Still, if there is a way to automate the process, I would be more than glad to learn about it :) best regards Kaarle |
Select the clips and choose Modify > Make Multiclip Sequence, then press OK to confirm and dismiss the Make Multiclip Sequence dialog.
This will automatically create a bin containing your multiclips (you can delete that bin and contents) .. plus it will create a Multiclip Sequence Open that Multiclip Sequence and you will find that your clips are arranged on the timeline such that their timecodes exactly match the sequence timecode (which is automatically set for you to start at the starting timecode of the first clip) Easy. |
