32" or 40" Screen Too Much?
I'm in a situation where I need extra screen real estate for my MBP--but once the basement studio build-out is complete (that is once it gets started..) I'd possibly use it for the Mac Pro tower.
The 24" LED Mac display is perfect of course with the newer MBP (power, display port cable), but a pretty expensive option all things considered for a relatively small screen. The 30" Cinema display is 2560x1600, which I feel makes everything way too tiny to be useful for editors (not to mention it is really expensive). I know some people have posted links to their edit suites where they are running LCD TV's. Best Buy has a really sweet 40" 1080P LED LCD 120mhz Samsung on sale for $1399 from $2199. Samsung - 40" Class / 1080p / 120Hz / LCD-LED HDTV - UN40B6000V That is actually cheaper than the 32" Samsung - 32" Class / 1080p / 120Hz / LCD-LED HDTV - UN32B6000V Of course that would look a bit silly sitting on a desk, huh? Do you feel a 32" or 40" LED LCD would fly for a main display? I think 1920x1080 is a pretty good resolution to work in for obvious reasons. Thanks in advance. |
I think the 40" screen will have the opposite problem as the Mac 30" screen. Menus and text are going to look huge at 1920x1080 on that big a screen... like the "large print edition". Personally, I think a 23" or 24" screen is a pretty optimal size for desktop use at normal viewing distance.
The old Apple 23" screen and some of the older Dell and other brands were offering 1920x1200 resolution which I kind of like for computer work - gives you a few more pixels for programs like Photoshop, CAD, etc. and FCP is "smart" enough to know to letterbox 1920x1080 video. I wanted to get another screen like this recently and looked at probably a dozen different models from Dell, Samsung, Sharp, etc. at Best Buy. Just about everything is 1920x1080 now. There was only one older model with 1920x1200 resolution and it was quite a bit more expensive than the same size 1920x1080 model. |
I have a Samsung 24" as a main display and that's about as large as I would want it.
I'm a bit surprised actually to hear you guys can't imagine needing/wanting more than 24" display. My other system is 2 21" CRT displays so I'm used to having lots of space. The problem with 16x9 displays is that a 24" gives you about the same height as a 17" (or maybe 19") 4x3 display. Once you get more than 3 or 4 layers on sequence you have to start scrolling up and down. If you move the Canvas and Viewer to a second monitor to get more vert space for the sequences, then you have to move your head back and forth. I'm editing on a 24" now at a client site and I'm trying to imagine this with a 24" Cinema display in front and my 17" MBP to the side.
My thinking is that on a larger 32" 1920x1080 screen you could drag the sequence portion of your screen up about 2/3 of the way leaving 1/3rd leftover for your Canvas and Viewer (Browser would go to 2nd monitor). Since the screen is so much larger you could keep the layers smaller in the seq and still have enough space to see the Viewer. I guess one could experiment within the 30 day return period, eh? |
I have a MBP 15" and a newer model Dell 24". I personally find my setup to be just perfect. I switch between the following arangements:
Browser on MBP and Canvas/Viewer/Timeline on 24" or Browser/Viewer/Timeline on MBP and Canvas on 24" |
Sorry Jeff, you've lost me there. The 40" or 32" screen is still 1920x1080 just like a 24". So all you get is bigger pixels, not more screen real estate. And you said you didn't like the Apple 30" screen which actually does have more pixels. So what exactly are you looking for?
I have a 24" iMac with 23" Apple Cinema Display connected via a Matrox MXO at work and find it a very nice setup for editing personally. At home I connect my 15" MBP to a 23" Apple Cinema Display as well. And I have a Dell PC with a 24" Dell screen at home too. These all work quite well for me. If I wanted to spend the money, I wouldn't have any problem with the Apple 30" screen. Personally I find one huge screen better than two smaller ones since I do things like CAD, photoshop and 3d modeling. |
Here we go, I found a couple of posts on this. I knew I couldn't be the only person thinking like this. Look at Glen's setup on this post.
http://www.dvinfo.net/conf/home-away...ml#post1179997 and some more from Glen Elliot: http://www.dvinfo.net/conf/non-linea...-action-2.html Quote:
That's all fine as far as I'm concerned. Everyone should use whatever works best for them. But you asked for our opinions and you got 'em. I have a 46" Sony Bravia in the living room and it's spectacular with bluray disks. NO WAY that I would want it "in my face" the way Glen has his.
To each his own.... |
Boyd, you are correct I did ask for opinions and I guess I didn't listen all that well. Thank you for your feedback. I'm still searching but leaning towards a 24" for now. As with all of this stuff, prices are dropping so maybe the wise thing to do is get something that does what I need now and not make too much of it.
Jeff |
