-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP crashing when trying to change settings (command-O) (https://www.dvinfo.net/forum/final-cut-suite/37823-fcp-crashing-when-trying-change-settings-command-o.html)
Ignacio Rodriguez January 15th, 2005 05:53 PM
Hi. I am running FCP 4.0, OS X 10.3.7, 768 MB of RAM, latest QuickTime et al, and when I try to change a sequence's settings (Command-O or the "Sequence/Settings..." menu) the application crashes. Is this a known problem? Is there a known solution?
The crash report says:
Command: Final Cut Pro
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Version: 4.0 (4.0)
PID: 362
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x000000fc
Ignacio Rodriguez January 16th, 2005 07:59 PM
Well, nobody replied. Anyway, the problem wnet away when updating to FCP HD 4.5. Cheers!
