Problems With Capturing XL2
Does anyone know what settings are needed to capture Xl2 footage to Final Cut Pro HD? Every time I try it gives me a dropped frames error. Please advise.
Thanks, Jeffrey |
There are a ton of discussions about capturing with the XL2. One
of the things you are not saying is which settings you are using. I did a search (button in the upper right corner) on XL2 restricting the search to just this forum and found the following threads (on just the first page) which I suggest you read: http://www.dvinfo.net/conf/showthrea...threadid=39166 http://www.dvinfo.net/conf/showthrea...threadid=36600 (also dropped frames) http://www.dvinfo.net/conf/showthrea...threadid=36966 http://www.dvinfo.net/conf/showthrea...threadid=35892 If this doesn't help you out, please supply some more information like: 1. settings in FCP 2. does it just happen at 24p for example, or also at 30p/60i? 3. capturing to internal or external drive? etc. |
just do it by "capture now".
