Nested sequence needs rendering?
Hello,
I have 3 sequences I want to put into one long sequence. But suddenly when I put a sequence into the big sequence it all needs rendering again? Usually just some audio needs rendering, this is new. Did I change some setting? Thanks, elmer lang |
If you have an effect on the main sequence, any changes to it will need re-rendering..., possible?
Another thought. Do the sequences have the same viewing options? It's not frequent to inadvertently change the settings, but stranger things happen.
