Importing XDCAM EX from folder
I need a bit of help.
Im trying to import BPAV folders into FCP yet the Log and Transfer does not show them when you browse the the folder. I have the BPAV folders sitting inside another folder as you should do. I managed to transfer footage directly from the EX3's USB port into FCP no problem but when it comes to loading footage off an external drive from a folder nothing appears. I could understand there might be a driver issue if the footage from the camera didn't work either but that was fine, Its only importing from folders where FCP is having an issue. I can see all the clips viewing from the XDCAM clip browser programme. Any thoughts James |
James, I'm fairly new to tapeless media and FCP so I'm not sure if this will be of any help. I have a JVC GY-HM700 camera that records either Quicktime wrapped files or MP4 wrapped files to an SDHC card. The SDHC card contains 2 folders one CPAV where my Quicktime files live in a folder named CLIP, and a BPAV folder where as I understand it the MP4 files would be if I recorded MP4 format clips. So I'm assuming that the BPAV folder also has a CLIP folder. I copy my Quicktime CLIP folder to my Scratch Disk and then drag the CLIP folder directly into my Browser Window, bypassing the Log & Transfer process. I'm not sure if this will work for MP4 clips. I also got a disk with my camera that has a JVC Log & Transfer program on it for using the clips with other editing systems besides FCP. A friend of mine has used this to import MP4 recorded clips that were shot with my camera into his Premiere edit system. I hope this was of some assistance evn though as I said I'm not really sure I know what I'm talking about. (LOL).
Dan |
