Burned DVD to Final Cut
Amazing I have never had to do this before. I have an old DVD that I edited years ago on my Avid system which sits in the corner of my office. The hardware has problems so I can't pull the footage off the system and I need to post the final DVD.
Question: How to I put a burned DVD into Final Cut Pro? |
I use MPEG Streamclip to:
First, repair timecode breaks - happens pretty much ALL the time with burned DVDs and then convert the VIDEO_TS to whatever editable format I want to use. Free download. |
Nice one thanks Shaun,
I use MPEG Streamclip all the time for POV work I will give it a go. |
No problem. Funny timing - I spent all afternoon pulling keynote speakers from DVD archives of multicamera live switched conferences using MPEG-SC! Hence the reason I'm REAL active on here today. Lots of downtime while MPEG-SC fixes TC breaks and encodes...
I've used Procoder many times to convert mpeg2 off DVDs to formats I can edit and never experienced 'timecode' breaks. What do you mean? There's no timecode on a DVD, is there? I rip the DVD. import VOB files and convert. Never had a problem, other than it looking like crap cause it's 'who knows how many generations away from the original video.' PS. Hope you're enjoying Vancouver! |
Not sure that it is "timecode" per se, although MPEG-SC reports it as such. I think it's a broken MPEG stream. In MY case, they typically aren't AUTHORED DVDs I'm pulling clips from, it's from a DVD recorder that I use to capture archival video of live multiswitched presentations with. DVCam is too expensive for 5 x 8 hour days, used to use VHS up until 4 years ago and there isn't enough margin or budget to use a PVR/HDD style device.
Any way, in a two hour DVD-R, I get about 100 "timecode breaks" so I fix them to reconnect the streams. I've been on FCP so long that VOB's never used to be editable until I found this solution so I stuck with it. I may be behind the times but my methodology is rock solid. Loving Vancouver. Still making trips back and forth and maintaining two residences for now. 21k kilometers in 3 months and one week on my brand new Subaru... |
There's timecode on DVDs but not SMPTE per se. It's just like consumer DV tape or even a QuickTime file. Each frame has a time number assigned to it.
DVDs created in DVDStudio Pro or Toast never have timecode breaks. It seems to only be on disks from DVD recorders. Probably a side effect from the live encoding and burning process while recording direct to a blank. A client sends me disks from a DVD recorder that doesn't need fixing, possibly a Sony recorder. I know from experience that Panasonic and JVC DVD recorders break the timecode |
The last time I worked with this kind of material, it was awful. The content was great, but the quality was just horrendous. But so many people are convinced that DVD makes a great aquisition medium. Anyway, glad Van is good for you. Best of luck with the new location. William, thanks for the clarification on DVD timecode. I wasn't aware of that. |
Thanks Shaun I will give it a try when I finish my current edit. MPEG Streamclip is a great piece of free software.
