Sequence Settings, Jpegs & Motion?
Does anyone here know the best sequence settings for a high quality jpeg slide show. I will be adding ken burns effect type motion the the images. The jpegs are large and high res. I would like my output to be 1080p.
What would be the best codec to use in the sequence settings for a project that only has jpegs with motion applied? |
What is the target playback device ? Blu-ray? Computer? Projector?
Target playback device will be computer however the video might go on dvd. Im trying to figure out which Codec/SequenceSettings to use to edit the jpegs in FCP to export an uncompressed high quality master copy. I can convert the master copy later to suit whatever i end up using it for.
Then what's wrong with ProRes 422?
ill give it a try
Another vote for ProRes IF (and this is a STRONG IF...) the playback computer will be a Mac with Final Cut installed. ProRes is NOT a ubiquitous codec.
