Weird FCP-Compressor-DVDSP problem
Hi,
I've been rendering / burning tests of an HD to SD project for DVD. Until recently I've had no problems but yesterday I did a test and for reasons unknown the resulting m2v file (exported directly from FCP to Compressor) looks awful - blurred and jittery. When I view earlier m2v renders in QT one can clearly see the interlacing lines which of course disappear when burnt to DVD (via DVDSP) and the video looks smooth when played back via a decent consumer DVD player. Recent renders however show no interlacing lines in QT and the m2v file looks blurred and horrible as does the DVD version. It's as if at some point the fact this is an interlaced project is getting lost somewhere. I've not altered any settings in Compressor that I know of except the bitrate - frame controls are off, field order automatic (top first) throughout. Anyone know what's going on? |
Kind of found the answer. The earlier successful files were exported as QT full quality first then imported into Compressor. The poor quality files were sent direct to Compressor and this is what is causing the problem. Just done fresh tests to confirm this.
So a kind of a solution but can't take advantage of the automatic edit / cut markers that are inserted automatically when sent direct which is annoying. Using FCP 6.0.6 and Compressor 3.5.2 so maybe this has been addressed with recent upgrades? Geoff |
Ok - found the solution! Since I wasn't deinterlacing I switched frame controls off in Compressor but tried turning them on and setting fields as 'same as source' and hey presto, fully interlaced file ensued!
