-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Livetype-Video Import Help Please (https://www.dvinfo.net/forum/final-cut-suite/49116-livetype-video-import-help-please.html)
Jeff Patnaude August 10th, 2005 09:04 AM
Hi guys,
I apologize if this has been addressed in the past. I couldn't find any threads in searching.
I've recently found these great templates on Livetype, and have been adapting them for use in my video work. The sample videos of the guy on the bike- how do you replace that? I've tried "Placing" and "Place Background Movie" several times without luck. I've also tried copying, dragging, and finally yelling. For the future, anyone else been able to achieve this?
I know it has to be something simple, and it's probably so close it could bite me. Figured I'd swallow my pride and field the question.
Any info always appreciated.
Jeff Patnaude
Jeff Patnaude August 11th, 2005 08:43 AM
found help elsewhere.
J Patnaude
Greg Boston August 11th, 2005 09:00 AM
J Patnaude
So Jeff, share the answer with the rest of us. ;-)
-gb-
Jeff Patnaude August 11th, 2005 02:08 PM
Sorry Greg-
I didn't realize there was any interest. It was really quiet there after for awhile.
I searched the internet and stumbled on an amazing training dvd:
http://www.dvcreators.net/products/ltps.html
I also found the answer, but I bought the training DVD just for the templates and clips that come with it- if not for the info on what is seeming to be an increasingly amazing piece of software.
To quote the info I found:(refering to "clips" template)
Click on the track that has the video. Each one of the videos will be represented in the text box as either a dot or a square. There will probably be 4 side by side, which makes the shape look like a dark rectangle.... YOu can select portions of the rectangle, in which you are actually selecting individual video files. (Instead of text, each character represents a video file). When you highlight one of them, go to Attributes, and then select the Matte tab. You should see some options of replacing the video. Select "Choose.." and find your video you want to replace the sample with. The video you have is probably much bigger in size than the templates, but the template will keep it cropped to the small size. You'll have to adjust the "scale" slider in order to make your video fit inside the box.
Livetype is SLICK! If there were little details that I missed prior to the training DVD, then I expect to raise the level of post work up a bunch with all of the stuff that the DVD covers.
Hope this sends out a collective "OOOooohhhhyeeeaaaaahhh..."
Jeff Patnaude :>)
Daniel Kohl August 11th, 2005 02:23 PM
I too have recently gotten a copy of the Livetype "power start" from dvcreators.net.
I don't understand why there is no documentation for this program from Apple. This program has a lot of features, and is very well thought out.
Maybe Apple was practicing for Motion.
