Split Screen Effect
Hey guys,
another post here.. so my client wants to do a split screen effect. She is using this as her example. YouTube - (500) DAYS OF SUMMER ? ReThink Review... i am editing on final cut pro 7. any suggestions to get this split screen effect as easy as possible without dipping into the Motion app? i know how to shoot and direct it, my only problem is editing it. thanks for your help! |
Re: Split Screen Effect
Clip 1 on Track 1. Apply Motion-Scale-50% and crop or otherwise mask to half the screen. Drag Stage Right
Clip 2 on Track 2. Apply same. Drag Stage Left. Then decide if you want the soft edges, or other aesthetic effects and apply those as well. Simple as that. |
Obviously a lot of the effect here is done during the shoot, so as long as you are okay matching what is happening on both sides at the same time etc (and also shooting on the same settings, with the same light and so on) it should be quite easy.
You also need to consider that unless you want to squash the image (you probably don't) you should only be shooting with half the frame. It doesn't really matter which part of the frame but maybe even using the same half for both sides and taping over the area not used as a guide... Then when you go into FCP, you place one video track above the other in the timeline, then crop the right side (if you shot on the left and covered the right) 50% or more and then reposition them and add filters for effect, as Bill said. Actually, a quick youtube search brings this up: YouTube - Daily Video Tips - Final Cut Pro "Split Screen" MC |
Inevitably there is an FCP plugin to do split screen. SplitScreen from CrumplePop works well & you just drag & drop the videos to where you want them. Products - CrumplePop: Master Templates for Final Cut Pro
You can also use DHBox from Digital Heaven: Digital Heaven - The Hottest Tools for the Coolest Apps
